Steering Colum
Old Dec 11, 2000 | 05:16 PM
Bort62's Avatar
Steering Colum
My steering Colum is Really Fricken Wobbly, Its a tilt and it wobbles from the Tilt joint, It is startnig to Get worse, So Im wondering How I can Fix this ? Is there a Part that wears out Inside or what ?
The Colum will still tilt, But then it just wobbles from the new, tilted location.
Its really starting to Bug Me, I swear it feels like its gonna come off in my hands one day Going Over a freeway overpass at 120 mph...
60 Ranchero - Project ( Money Hole )
85 Z28 LG4 - Daily Driver
**Mods**
MSD Superconductors
14" Open Element
KYB all around
Old Dec 11, 2000 | 05:38 PM
Kevin S's Avatar
What you need to do is remove the steering wheel,hub and tilt assembly.there are 3 bolts down inside the column that work themselves loose.Once you remove the wheel and tilt assembly you will need a looooong extension and socket to reach those bolts.
It would be wise,if you can...to apply some lock tight fluid to those bolts.It's not to difficult.....just time consuming .
It would also be wise to purchase the tool that compresses the spring to remove the snap ring on the steering shaft.I'm not sure what the name of this tool is.It will help to make childs play out of this repair.
http://www.camaroforum.com/
http://v6fbody.com/
http://nethirdgen.org/
http://clubs.yahoo.com/clubs/tristatecamaro
[This message has been edited by Kevin S (edited December 11, 2000).]
Old Dec 11, 2000 | 05:42 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Yeah, what he said...
Without the tool, you'll be in for a long, frustrating afternoon of work. It's still doable but a real PITA.
Old Dec 11, 2000 | 10:17 PM
Vader's Avatar
Bort,
These are the bolts (Torx) that you need to tighten.
Remove them one at a time, clean the threads, apply LocTite 242, and torque them to 80 in/lb (about 6½ ft/lb). Any more will strip the die cast housing, and you'll really be screwed.
Later,
Vader
"No matter how hard you try you can't stop us now"
Adobe Acrobat Reader 4.0
Old Dec 11, 2000 | 10:42 PM
Bort62's Avatar
Thanks guys, Looks like I can add that to Thursdays To Do List Along with replaceing the PS pump and Putting in the Vaccum Dist :0
**Mods**
MSD Superconductors
14" Open Element
KYB all around
Old Dec 11, 2000 | 11:37 PM
JP84Z430HP's Avatar
Car: 84 Z28
Engine: 355 (fastburn heads, LT4 HOT cam)
Axle/Gears: 9-bolt, 3.27
The official name for the tool is a "Lock-Plate Depresser", in case you have to ask for one from the parts store. I just got a new one (Old one decided to leave my possesion) and it was under $20.
Good luck!
Working on:
'84 Z28 LG4 305
Added dual elec fans.
145 MPH IROC Speedo
Building 430 HP 350
using primarily GMPP parts.
Block is in shop!
Awaiting results from all 8 ASE tests.
Starting to look like the Kicker poster child!
Ed1LE
Sep 30, 2018 09:14 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
loud91rs
Oct 5, 2015 10:05 PM
sjorgens
Oct 1, 2015 07:54 PM
Night rider327
Sep 25, 2015 04:19 AM
