Lots more ?s about A/C Removal
Old Dec 9, 2000 | 10:55 PM
Dan87IROC-Z's Avatar
Does anyone have any pics of their car they can display or give me links to with the A/C removed? How hard is it to pull that black box on the fire wall out? How much dissconnection and other such is involved in pulling that thing out? It looks like its a real chore to dissconnect and get out. Is there going to be a huge hole in my fire wall after I take it out?
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission with 2.77:1 Rear End
Current Mods: Edelbrock TES 1 5/8" Headers, Hooker 3" Aerochamber Cat-Back System, Performance Resource Chip with 160* Thermostat, Accel Ignition Coil, Cap, Rotor, 8.8mm Wires, K&N Filters, JET TPI Air Foil, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET : 14.32 @ 97.7mph
(corrected for elevation)
Soon to come: LT4 HOT Cam, Air Flow Research 190cc Heads, 2800 RPM Stall Converter and SLP 3.70 Rear End Gears.
Old Dec 10, 2000 | 09:09 AM
ede's Avatar
ede
we did it to my sons car. wasn't that hard. unhooked the lines, removed the compressor and all the associated hardwear and brackets. took the blower box off the firewall and replaced it with a non-ac blower box. you can't tell it ever had ac and it's lighter and easier to work on.
ICON Motorsports
1st & 3rd
Old Dec 10, 2000 | 11:09 PM
crazeinc's Avatar
this is the complete removal:
The '82Z
Hugger Orange
383 4 bolt main
3000 lbs
Bad cornering
NOS Sportsman Fogged
10 bolt braker
Coming to a street near you in the spring...
The car's website
Old Dec 10, 2000 | 11:22 PM
crazeinc's Avatar
I guess showing you a picture doesn't help much...you just basically just start unbolting and ripping stuff out...when you're all done you'll have 2 holes in your firewall...I screwed in 2 pieces of sheet metal and painted the entire engine bay and it looks really nice....just for some flavor I put those stickers on there so the plates weren't as noticable. Maybe this winter I'll bondo the entire wall and give it a smooth look.
damn, I did it again... When you unbolt the "big black box" from the firewall you will have the 2 holes, but like ede said there is a heater only box (much smaller, try a junkyard for one) and that will cover up both of those holes...It looks really nice. Let me dig up another picture for you.
[This message has been edited by crazeinc (edited December 10, 2000).]
Old Dec 10, 2000 | 11:27 PM
crazeinc's Avatar
is this kicka$$ or what?
Old Dec 12, 2000 | 12:28 AM
Thanks a lot guys. If I pull that black box out of the back of the engine compartment, will my other accesories like de-frost and heat work, I live in Colorado so those are sort of nessassary.
L98 TPI 350 (5.7L)
Old Dec 12, 2000 | 01:38 AM
Bort62's Avatar
No, You hve to replace it with a Non AC box.
60 Ranchero - Project ( Money Hole )
85 Z28 LG4 - Daily Driver
**Mods**
MSD Superconductors
14" Open Element
KYB all around
Old Dec 12, 2000 | 06:58 AM
Baz89RS's Avatar
It looks more dificult then it really is, once you start unbolting and taking things apart it's pretty straightforward...
I don't even remember the steps when I did mine so it shouldn't be much at all....
Old Dec 12, 2000 | 08:55 AM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
Also going to need a new hampster wheel for a non AC for your blower motor.
Old Dec 12, 2000 | 09:56 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
You could also go the way I did; I removed the a/c compressor and condensor and accumulator. I left the evaporator in it's hole in the heater/evap box on the firewall. I got the evaporator from my parts car; it's a/c system was already discharged from years of sitting.
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
jaridjohn
Jul 8, 2024 03:49 PM
Frozer!!!
Jan 19, 2024 04:55 PM
BikeFarm
Aug 11, 2015 11:35 PM
3rdgenparts
Aug 8, 2015 07:09 PM
