Give me a stall.
Old Dec 11, 2000 | 10:20 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
Give me a stall.
Ordering Vig 9.5 tongiht and need to give them a stall. What would you guys recommend?
89 FORMULA 350 Edelbrock Cat-Back ,March Pulleys,Super Coil,MSD 6AL ,Edelbrock TES's, AFPR ,Shiftkit, Edelbrock Base ,AS&M Runners, Edelbrock Waterpump, Fast chip,Crane Gold 1.6 RR's, MSD 22# Injectors.
Old Dec 11, 2000 | 10:33 PM
MrJ's Avatar
MrJ
2800 or 3000. Don't **** around with anything lower, you'll regret it in the long run.
91 Trans Am WS6
Bright White
5.0 TPI auto
Flowmaster 3" 2 chamber catback
Trans Go shiftkit
2000 stall converter
supposed 'peanut cammed' car (yeah, right)
Built on Wednesday
Old Dec 11, 2000 | 10:36 PM
cobrakiller1989's Avatar
im running 2600-2800 and i like it alot. I dont have anything to compare it to, because htis is my first one. But i definitely recommend it.
Old Dec 11, 2000 | 10:49 PM
IROCZZ3's Avatar
Car: 87 Buick GN
Engine: 3.8L (231 cid) V6
Transmission: 200-4R
Axle/Gears: 10 bolt G80/ 3.42
I agree with MrJ...don't let anyone tell you 3000 is unstreetable. As long as you get a QUALITY converter (Vig, Protorque, or Yank) driveability will not be changed much.
I have a TCI 2400 but it flash stalls at about 2000...it sucks.
Myself, I'll be getting a Yank 3000 pretty soon.
1989 IROC-Z, ZZ3 shortblock with some bolt-ons.
13.20 @ 108.69, 2.2 60'
Old Dec 12, 2000 | 08:55 PM
406 S10 Man's Avatar
Car: 1971 Corvette
Engine: 6.0 LS1 L92 heads sheet metal etc.
Transmission: M21 4-speed
Axle/Gears: 3.36
My TCI Streetfighter stalls at around 3200 and I love it. I am running a fairly large cam for the street (240/244 duration @ .050) and my old converter wouldn't allow the engine to idle. My Streetfighter is totally streetable and doesn't slip too much while I am cruising.
I would suggest a little less for your car though. 2800 like MrJ said sounds good. As you increase your engine's power, the stall speed will rise, so that converter should be good until you get really nuts on the mods.
88 S10
Lowered 3/4
Dart equipped 406
12.20 @ 115.25 mph
darwinprice
17
Oct 11, 2015 11:51 PM
bjpotter
Oct 4, 2015 07:48 PM
racereese
Oct 3, 2015 03:46 PM
Fanatic1074
Oct 2, 2015 03:47 PM
Linson
Oct 1, 2015 09:50 PM
