huge turbo on a 350 TPI
Old Oct 29, 2003 | 06:21 PM
stevedave454's Avatar
Car: 91 S10
ok, im putting a 350 mass air TPI in my 91 S10 (i know i know, its not a 3rd gen, but i didn't where else to go for advise) the motor has (will have) a T-78 turbo strapped to it, large cam, etc. i've heard mass air has a lot of small problems, and speed density is much better, but i have also heard speed density doesn't work with large cams, and i have no clue if it works with forced induction. i wanted some input on that aspect. i was also curious about using other maf sensors. i know DSM's (mitsubishi/eagle) use lt1 or ls1 maf sensors, and i was wondering if i could on my TPI due to the higher flowing, and cheapness. one last thing this turbo makes about 800+ HP an a 6 cylinder supra, im not sure what it will make on my 350, but any suggestions for computer tuning???
Old Oct 29, 2003 | 06:59 PM
Merlin's Avatar
You can use a stock MAF, or a MAP sensor for your project. You cannot use a LT1 or LS1 MAF on the older ECMs used in our cars.
A 2-BAR MAP sensor would need to be used with any boost. Search the archives for that topic.
Old Oct 29, 2003 | 07:19 PM
Car: 91 S10
and the 2 bar map sensor is for speed density correct?
Old Oct 29, 2003 | 07:53 PM
Greasemonkey's Avatar
Car: 86 Cutlass
Transmission: 200-4R
The 749 (Syclone) ECM is the ECM that can deal with the 2, and 3 bar Map sensors.
Old Nov 8, 2003 | 01:31 AM
85ws6TA's Avatar
Car: '92 Typhoon/ '79 Vette
Engine: Turbo 4.3L/Forged 355ci
Transmission: 4l60/th350
Re: huge turbo on a 350 TPI
*** i hate you.
check out turbo sunbird ECMs too. i think thats what Sy/Tys use, and it probably be chaper if you can find one.
Old Nov 8, 2003 | 10:25 AM
zippy's Avatar
Car: 2006 Silverado 1500
Engine: 5.3L
i'd check into the mass air project a bit more. i've seen quite a few with an LT1 maf conversion. i don't recall who makes the conversion, but you're obviously going to have to be programming the prom specific anyway so i'd check into that first and use a 3 bar map sensor which as i recall was used on the tta.
Old Nov 8, 2003 | 10:59 AM
rhuarc31's Avatar
Car: 89 Formula 350
Engine: 409 nitrous' small block
Head on over to the power adder board and the diy prom baord. more specific info over there
theurge
Aug 21, 2015 12:46 PM
Out-Cast
Aug 17, 2015 10:57 AM
Jlanz55
Aug 17, 2015 07:15 AM
bamaboy0323
Aug 15, 2015 07:20 AM
wruiz
Aug 13, 2015 09:07 PM
