Burn off Relay???
Old Dec 13, 2000 | 11:47 PM
Steve R's Avatar
Burn off Relay???
Which relay is the burn of relay? I need to replace it - who carries them?
-80 Camaro 350, Carter AFB, headers, dual exh, ram air, all sorts of crap
-88 Iroc-Z 350tpi, 3.27 gears, 4 wheel disc, MSD 6a, tpi airfoil, k+n's, white gauges, accel coil, flowmaster, pretty quick
Old Dec 14, 2000 | 12:09 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
It's placed on the firewall on the drivers side , there are three relays and the burn off is the on the "passengers side", in middle "fuel pump" and on the driversside "MAF power".
GTA -89:Free flow muffler,dual 3" HF cats, Edelbrock headers, Vette heads, 1.52 RR 7/16, ZZ-9 cam, Big Mouth, AS&M LTR, !plenum, 52 TB, MSD 6AL, TPIS level V prom, Superior shift-kit and all the minor mods. and more to come!
http://www.itv.se/tacs/members_cars/m279/m279.html (Swedish Trans Am Club)
Old Dec 14, 2000 | 08:12 PM
rondubbs's Avatar
Gta324 is correct, that is where they are located on PONTIACS,, i noticed in your signature you have a CAMARO, i believe they setup is different. you better double check!!
you can get the relays at GM parts dealer.
Falcon50
Aug 22, 2020 03:26 PM
thunder57
Nov 7, 2015 02:28 PM
Thornburg
Aftermarket Product Review
Oct 6, 2015 12:04 PM
lanceflame44
Sep 25, 2015 12:28 PM
