problem with daily driver, it's winter in Michigan. (not 3rd gen related).
Old Dec 14, 2000 | 06:44 PM
JDMZ28's Avatar
Car: 2KGTP
Engine: supercharged 3800 L67
Transmission: 4T65E
Axle/Gears: 2.93
I have a 92' Grand Prix with a 3.1 V6 as a daily driver. Yesterday I incountered something very odd.
I was sitting in my friends driveway with the engine running when I noticed my normally smooth-running engine was idleing rough. I also noticed my windshield becoming foggy even though the defroster was on. I put my hand over the vent and felt cold air coming out of it even though it was on max hot. I then glanced down at the gauges and noticed the SES light was on and the oil pressure gauge was at 0 psi. I shut the engine down and went inside. An hour later I came outside started the car and everything was normal. I drove the car all day today and nothing went wrong. I checked the oil and coolant and everything seems to be ok. WHAT THE HECK COULD THIS BE?????
Why would the defroster and oil pressure be affected at the same time? I think its a sensor. I don't know if this would have an affect but I think my cat is going.
1986 CAMARO Z28 -> 151,000 original miles, 43,000 on 89' vette 350 block, Holley 650 DP, Weiand intake, 1.6 rockers, 1 5/8" headers, no cat, 2 1/2" Flowmaster catback, Mallory coil, March pulleys, T5 with 3.35 1st gear, 90% Centerforce clutch, 3.73 posi, Eibach 1" drop springs, Spohn LCA's, Spohn adjustable panhard rod, Subframes connectors, polyurethane swaybar bushings/endlinks, 2 12" Sound Streams, 2 Infinity 6X9's, 2 Pioneer 6X9's, 800 watt Lanzar Vibe amp. ET 13.22@ 106.4MPH Next mods-> Homemade ram air, B&M shifter, Extreme Energy 230/236 cam, Holley Street Dom intake.
Old Dec 14, 2000 | 07:55 PM
jmon92conv's Avatar
Have you checked the codes? That is where I would start at. BTW kickers are great until they screw up. I love mine.
Jeremy
92 Z conv
5-spd B&M
alston SFC, few mods, some free, some not
Old Dec 14, 2000 | 08:33 PM
Vader's Avatar
JDM,
J-Mon is right. Scan for that error code and you'll probably get a hint as to what is going on. The codes remain in memory for the last 50 engine starts, so you should retrieve the codes soon.
Later,
Vader
"No matter how hard you try you can't stop us now"
Adobe Acrobat Reader 4.0
colton_carlson
Mar 8, 2019 12:21 PM
Infested
May 22, 2018 11:56 PM
Adamki2000
Brakes
24
Dec 20, 2015 10:40 PM
InfinityShade
Aug 22, 2015 08:00 PM
NWAsonoma
Aug 18, 2015 05:45 PM
