Help in trouble shooting ESC?
Old Dec 14, 2000 | 06:20 PM
new87's Avatar
Car: 87Z
Engine: ?
Transmission: A4
OK the car died last night and hasnt started, sence than. I hit it with a shot of ether to see if turned over no luck (thinking it was a frozen gas line), a guy at work told me that the ESC can just up and die like that. How do I find out for sure?
87 Z28 305 TPI, Auto, 2.77, Gutted air boxes, K & N fillters, Dyno Max 3" cat back, Accel 8.8 mm spirals, Accel cap and rotor, Accel coil, rapid fires, and 160 Stat.
Best 15.414 @ 87.47, 3.23 and SLP airfoil on the way!
Old Dec 14, 2000 | 08:24 PM
Vader's Avatar
New,
Even if the ESC died, you can bypass it by disconnecting the timing wire. If, however, you are talking about the HEI module, they can fail without warning and the only fix is to replace it.
Remove the module, take it to Ought-Tow-Zone and have it tested. Make sure there is voltage at the BAT/IGN terminal of the distributor. Make sure eh reluctor and pickup coil aren't damaged. Check the ignition coil and coil wire. Look for moisture (snowmelt) in the distributor cap and on the rotor.
Later,
Vader
"No matter how hard you try you can't stop us now"
Adobe Acrobat Reader 4.0
Old Dec 14, 2000 | 08:36 PM
new87's Avatar
Car: 87Z
Engine: ?
Transmission: A4
Vadar your right, the HEI control is what I mean. Some I can take it out and they can test it at the good ole autozone.
RedLeader289
May 28, 2019 01:47 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
meeklay812
Oct 1, 2015 03:46 PM
3.8TransAM
Sep 27, 2015 08:37 PM
Lmancha96
Sep 25, 2015 08:11 PM
