4th gen fuel pump problem
Old Nov 1, 2003 | 04:37 PM
peruvious's Avatar
Car: 1991 Z28
Transmission: t-5
ok i know this isnt a thirdgen, but i had no one better to ask.
my g/f just got a 95 v-6 camaro we bought it for 1k knowing that there was a fuel pump problem. well after countless hours and beating of the car, i got the pump out. i changed it and tried testing it. the resister works fine and checked out, but i found out that there is no power even getting to the fuel pump, i took a voltmeter to check from the plug coming out of the bottom of the car and there is no juice from the power wire. i started looking for the fuel relay and all but i was unable to find that to check......does anyone know how i can fix this problem so the fuel pump will turn on...
Old Nov 1, 2003 | 09:33 PM
peruvious's Avatar
Car: 1991 Z28
Transmission: t-5
ok i know what ur probably going to say, its the fuel pump relay....yea i know this now after i posted this, i went out to check the relay. popped the hood and started looking where all the relays are at, i see no lable for the fuel pump relay.... i had a buddy of mine look too and couldnt find it...is it under a different lable or is it not with the other relays?
Old Nov 1, 2003 | 11:19 PM
ChevTech84's Avatar
If I'm not mistaken that relay is under the dead pedal on the drivers side floor pan, good place for it huh.
Old Nov 1, 2003 | 11:29 PM
Morley's Avatar
It is behind the driver side kick panel
Old Nov 2, 2003 | 11:25 AM
peruvious's Avatar
Car: 1991 Z28
Transmission: t-5
thanks alot guys
Old Nov 3, 2003 | 03:20 PM
Vader's Avatar
This really isn't a ThirdGen topic...
Frozer!!!
Jan 19, 2024 04:55 PM
92camaroJoe
Jul 29, 2023 07:57 PM
AkDrifted
Aug 17, 2015 07:45 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Newguy91rs
Aug 7, 2015 09:51 PM
