The 85 Vette That only revs to 2600rpm??
Old Nov 1, 2003 | 08:16 PM
86Tra/maro's Avatar
From: Newark,NJ The state where racing on I 78 rules.
Whats up everyone?
I have a car thats giving me fits with the extremely rich exhaust & black smoke comming out of the tail pipes. The car is a 85 350 tpi vette with a 383, 22lbs, stock intake, 262 or 264 comp cams. Does anyone know what could cause this? The car stops reving at around 2800 rpm & It starts to back fire through the intake & Exhaust. When I put it on the computer the INT was steadily going down in the 119 range & droping. The timing was set at 6deg. with the dist wire disconnected. The throttle was set at .54v . Im lost. someone please shed some light on this situation.
Thanx
Old Nov 3, 2003 | 06:19 AM
Quick_Trans_Am's Avatar
Car: 1985 Pontiac Trans Am
Engine: 355 with stuffs.
Axle/Gears: 4.10 Posi
any trouble codes? how's your fuel pressure? test it and see if you have a leaking injector, or a bad diaphragm in your fuel pressure regulator. That may not be the cause, but It's sure where I would start. Hope that helps.
Old Nov 3, 2003 | 07:13 AM
MARKT111's Avatar
Car: 1989 TTA
Engine: 3.8 Turbo
Transmission: 200R4
clogged cat happened on my 86 TA, would not rev over 3000RPM in nuetral, the best thing was it probably melted over time so when I hollowed it out(I mean replaced it)the car felt like a rocket
gta892000
Aug 11, 2019 11:16 AM
RedLeader289
May 28, 2019 01:47 PM
FormulasOnly
Jul 23, 2018 08:47 AM
BDR
Nov 7, 2015 03:05 PM
ndndndnd
Carburetors
Sep 16, 2015 04:13 PM
