Whining noise from engine compartment.
Old Dec 14, 2000 | 09:30 PM
SGT SWEETPANTS's Avatar
There is a high pitched whining noise coming from my car. When the hood is open it is louder, therefore I have deduced that it is coming from under the hood. Also, it is present at idle and increases with the rpm. My only guess is the water pump, but I don't want to go replacing parts without knowing for sure.
'86 IROC-Z
305 LG-4, T-5
T-Tops
50k Original Miles
K&N Air Filter
Stage I Chip
KYB Shocks/Struts
Centerforce Dual Friction
Old Dec 14, 2000 | 09:37 PM
Vader's Avatar
Sarge,
Other options are the alternator, A.I.R. pump, air conditioner clutch hub bearing, power steering pump, a vacuum hose that is split (in which case the pitch should go DOWN with increased throttle openings), or an engine bearing.
Chances are you can remove the acessory drive belts one at a time and find the offending device.
Later,
Vader
"No matter how hard you try you can't stop us now"
Adobe Acrobat Reader 4.0
Old Dec 14, 2000 | 09:46 PM
I don't have a/c and the alternator is new, so hopefully I can rule out those, but I will give it a shot. Thanks for the help.
'86 IROC-Z
305 LG-4, T-5
T-Tops
50k Original Miles
K&N Air Filter
Stage I Chip
KYB Shocks/Struts
theshackle
Sep 17, 2020 08:26 AM
Infested
May 22, 2018 11:56 PM
B_Dubya
Aug 26, 2015 05:09 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
BlackBoulder
Aug 11, 2015 11:15 PM
