LT1 intake swap
Old Nov 2, 2003 | 01:23 AM
stevedave454's Avatar
Car: 91 S10
LT1 intake swap
first of all if this is the wrong place to post this thread let me know - ok i've been reading a little about it, and i checked out lt1intake.com, but i still have a few questions.. what harness and ecm do i use? should i modify my TPI harness or get an LT1 harness and ecm, and if i need the LT1 harness/ecm what year is the best? OBDI or OBDII? and im guessing the LT4 intake wont work due to the higher ports, is this true? where can i get a lot of info on this topic? also, is there a different intake setup that will flow better (in the high end) for the same approximate price?
Old Nov 2, 2003 | 07:06 AM
Vader's Avatar
I'd suggest using the TPI harness. There should be very little modification if you get the LT1 intake machined for a regular distributor. A stock TPI ECM would go with that.
You can get a lot of information if you perform an archive search.
Old Nov 2, 2003 | 09:08 AM
Rippin92RS's Avatar
Car: 1992 Camaro RS
Engine: 305 TBI
Transmission: GM T56
Yep Vader's right.
Stealh Ram. It's top end crazy. And like $300 from Summit.
-Rippin
Old Nov 2, 2003 | 11:28 PM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
Re: LT1 intake swap
Most of your questions are already answered in the FAQ on my site.
http://www.lt1intake.com/faq.htm
Old Nov 3, 2003 | 03:06 AM
Car: 91 S10
ok, now i know a little more and need some opinions - which would be better for top end (6500-7500) stealth ram or LT1? im expecting to hear that neither will be good for that high of rpms but as far as i know these are my only options due to $$$
Old Nov 3, 2003 | 07:08 AM
85TransAm406's Avatar
Car: 1985 Trans Am
Just did my LT1 intake conversion from John, it pulls plenty hard up to 6000, seems like it can go higher, but i have a pretty small hydraulic cam on my 406, as i am getting into road racing, so i dont try to go higher.
midge54
Sep 2, 2020 07:13 PM
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
dbrochard
Fabrication
16
Aug 19, 2015 06:21 PM
sreZ28
Aug 14, 2015 07:48 PM
