CS-144 alt swap pics with the serp setup.
Old Nov 2, 2003 | 02:29 AM
Kat's Avatar
Kat
Car: Camaro Vert
Engine: 355 HSR
Transmission: A4
Axle/Gears: 3.73 S60
Well a few months ago a friend of mine picked up a bracket for me to swap the bigger CS-144 140 amp alt into my IROC.. Heres the pics.
On the left is the stock thirdgenb serp bracket and the one on the right is the serp bracket outta a 93 TBI 9C1 Caprice
Heh just look how big it is! Hence why I wanted to switch to it.. And it has more output..
That is what it looks like at home. Don't mind the mess in there. The engine bay is one thing I haven't felt like cleaning up at all in that car.
As for the swap.. The hardest thing was swapping out the bracket. One 9/16ths nut and four T45 bolts later it was off.
The only real obsticle was that the wire from the alt that goes to the batt, you have to make the hole bigger for the eyelet.. Even the stock plug for the alt plugs right into it.
Kat
Old Nov 2, 2003 | 11:11 AM
TechSmurf's Avatar
Car: '99 Trans Am, '86 Camaro
Engine: LS1, Scrap
Transmission: T56, T5
Axle/Gears: 3.42 Stock ZT, 3.42 Open
The eyelet not being big enough was supposed to be a hint.. time to replace your alt cable. The stock one may not respond awfully well to a max output just short of 2000 watts. You *could* melt the wire and cause a rather destructive short (alternator would probably fry, and battery would fry/overheat/melt down/explode, etc). I remember doing a little accidental arc welding with my alternator wire, so I'm pretty sure it's unfused.
Other than that, looks hella nice.. now I want one
customblackbird
Aug 15, 2021 10:16 PM
1984HO
Mar 19, 2021 11:59 AM
gta90
Sep 15, 2015 04:00 PM
masonta
Aug 31, 2015 10:14 PM
Street Lethal
Aug 13, 2015 08:28 PM
