Do you think I milled heads too much ??
Old Dec 14, 2000 | 09:57 PM
JJ's Avatar
JJ
I previously had a 305 and bought the vortec heads and milled them .030", well, I got the gmpp 350 that came with vortec heads and had 9.0 to 1 compression. I went ahead and put a new cam in so I put the milled heads on also. The cam is 224/230 , 470/480, I had a valve job and got better springs and did use normal thickness head gaskets. I figured since the engine was 9.0, the milled vortec's would put it around 9.5-9.7 to 1 compression. You all will cringe, but I just put them on without checking clearances. Well, I'm going to pull them off here before long and probably get 2.02/1.60 valves put in them. When I re-assemble, I figure I will use the clay method and was wondering the "exact" procedure for this and what clearance I should look for ?? Thanks guys
Old Dec 14, 2000 | 10:08 PM
Vader's Avatar
JJ,
I'd be scared with much less than 0.040" clearance.
The procedure I'd use (whether it's correct or not) would be to mold a piece of clay into the valve reliefs in the piston top, set the head in place with a used (already compressed) gasket, snug up a few head bolts by hand, and install a couple of push rods and rockers. Crank the engine over slowly at least two revs, then remove the head. check the thickness of the clay where the valves made their impressions.
Forty thousandths of float is not unheard of at higher RPMs, and you don't want to the valves to deliver the "kiss of death" at 6,800. You'd probably never find all the pieces.
Later,
Vader
"No matter how hard you try you can't stop us now"
Adobe Acrobat Reader 4.0
Old Dec 14, 2000 | 11:14 PM
JJ's Avatar
JJ
thanks, I'll be sure to do that
Hotrodboba400
Dec 10, 2019 07:07 PM
92projectcamaro
Jan 18, 2016 08:00 AM
FormulasOnly
Sep 6, 2015 10:42 AM
z28guy134
Sep 1, 2015 11:50 PM
