Vortech heads and EGR
Old Dec 14, 2000 | 11:34 PM
Bort62's Avatar
Are there any Vortech heads With an EGR passage ?
And Does anyone Make an intake with EGR provisions For the vortech Heads ?
Basically, Could I build a Smog Legal motor Using these Heads ?
60 Ranchero - Project ( Money Hole )
85 Z28 LG4 - Daily Driver
**Mods**
MSD Superconductors - Vaccum Advance Distributor
14" Open Element - Mech Qjet
KYB all around - Smog EQ Mostly Removed.
Best ET as of yet : 3 hours + to Drive To the Nearest Track
Old Dec 15, 2000 | 12:02 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Are you in an "enhanced smog" area of CA? If so, then probably not, unless you find a friendly smog check place. I'm using the L98 Corvette heads, with a TPIS Big Mouth intake manifold, and I am hooking up my EGR like the Corvettes do. They use a tube off the #8 header up to the back of the intake manifold. Then I can recertify my engine as a 91 Corvette. You can do the same, but the Vortec heads are iron, not aluminum...
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old Dec 15, 2000 | 06:23 PM
zenish's Avatar
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
don't trucks with vortec engines have egr?
Old Dec 15, 2000 | 11:43 PM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Yes TRUCKS do, and you hit the nail on the head, truck motors are not legal in cars. They have a special intake to accomodate the EGR with a connection to the exhaust manifold.
Chronologically challenged. But still alive!
92 CAMARO RS
305 TBI 5/spd
'69 camaro
BB/Lenco
1050 dominators
8.97-150+
Pump gas/no drugs
injdinjn
Aug 28, 2015 12:51 PM
Bubbajones_ya
Aug 28, 2015 02:17 AM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
drathaar907
Aug 6, 2015 04:20 PM
