Corvette heads
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
Corvette heads
Can some one tell me about this casting number? 10088113
James
If the women don't find you handsome they should at least find you handy
Aftermarket T-56 (pain in the A$S but worth it)
Lots of things to do still
James
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Year: 88-up
Casting#: 10088113
Intake: 1.94
Exhaust: 1.5
Chamber: 58cc
Angle plug, aluminum, Vette, raised (.100") D-port exhaust
Stephen's racing page
87 IROC-Z Pro ET Bracket Race Car
383 stroker (carbed) with double hump cast iron heads and pump gas
454 Big Block buildup now in progress for the 2001 racing season
Best results before the 383 blew up
Best ET on a time slip: 11.857 altitude corrected to 11.163
Best MPH on a time slip: 117.87 altitude corrected to 126.10
Altitude corrected rear wheel HP based on power to weight ratio: 476.5
Best 60 foot: 1.662
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Casting#: 10088113
Intake: 1.94
Exhaust: 1.5
Chamber: 58cc
Best 60 foot: 1.662
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
They are '87 and up corvette and zz3-4 crate engines,
Chronologically challenged. But still alive!
92 CAMARO RS
305 TBI 5/spd
'69 camaro
BB/Lenco
1050 dominators
8.97-150+
Pump gas/no drugs
92 CAMARO RS
305 TBI 5/spd
'69 camaro
BB/Lenco
1050 dominators
8.97-150+
Pump gas/no drugs
Car: 92 Firebird
Engine: 4.8 LR4
Awesome. I cant believe I got an answer that fast. Thanks guys. Now I just have to get the broken bolt out of one of them.... Actually I have a question about the guide plates on them. Are they factory that way? Can I remove the guide plates (are they screwed or pressed in). And Should i use guide plates or self aligning rockers?
James
James
Guest
Posts: n/a
I would use guide plates. The rocker studs screw in, so you just have to unscrew them to get the guide plates off. From what I hear, some of them came with guide plates, and some didnt. Mine had them. Good heads though, respond really well to porting.
Car: 1987 Z28 Convertible
Transmission: 5-speed
Willie
Supercharged 1987 305 IROC-Z, Daily-Driver, Emissions-Legal.
12.57 @ 111 mph.
12.04 @ 114 mph (50-hp nitrous).
http://members.optushome.com/au/downunder1/rides/willie/willie.html
1987 "20th Anniversary Commemorative Edition" Z28 Convertible -- Super Chevy Show Class Winner, 1998.
ambainb
Apr 25, 2016 09:21 PM
