car is running like its flooded at start up.
Old Nov 4, 2003 | 10:00 AM
Z dude's Avatar
Car: 1991 Z-28
Engine: TPI
Transmission: 5-speed Rear:3.73
I noticed today that the start up smoke that I see is different than I thought,the car starts up fine but sputters and smokes for a couple minutes like a carb. engine would if the choke was closed and it was flooding ...then runs smooth and no smoke,the smoke is like gas smoke .....If I keep my foot on the accelerator and keep the rpm's up at start up it clears out faster,what the heck is up with it,its TPI and runs super other than this,any ideas?? I know it had a Holley fuel pump installed in the tank before I bought it would that have anything to do with it,too much gas or something,im lost
Old Nov 4, 2003 | 07:27 PM
Vader's Avatar
Can you report what the fuel pressure is? Does the fuel system hold pressure after engine shut down?
Have there been any modifications?
Old Nov 4, 2003 | 07:33 PM
reilly8282's Avatar
Car: 1988 IROC
Engine: l98 350 tpi
leaky fuel injectors.
Old Nov 4, 2003 | 07:42 PM
Z dude's Avatar
Car: 1991 Z-28
Engine: TPI
different runners(SLP),MSD,air foil,k&n's,cam,1.6 rockers,Hooker headers,3" Flowmaster all the way back,etc. etc.
I cant remember it all,
leaky fuel injectors??
Old Nov 4, 2003 | 09:52 PM
reilly8282's Avatar
Car: 1988 IROC
Engine: l98 350 tpi
yes, fuel injectors will leak after time, and they drip and drip, which causes it to almost flood.....when you start it up it takes a little cranking to start then blows out a puff of blackish grayish really gassy smellying smoke which is the burn off of the gas that has been leaking threw while the engine was shut off. If you try a search and read some of the posts im willing to bet thats your problem
theshackle
Mar 5, 2017 06:37 PM
Wade787b
Sep 29, 2015 01:15 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
