Heater Question
Old Dec 16, 2000 | 03:03 PM
John 89 Formula's Avatar
Car: 89 FORMULA FIREBIRD, 86 CHEVY CAMARO
Engine: L98, LB9 RESPECTIVLY
Transmission: 700 R4 (BOTH)
Heater Question
In my car, no matter where I set the heater control the darn thing only blows out the defroster vents. The vacuum cans that work the doors inside the heater unit are not getting vacuum, where is the main vacuum source, and what else should I be looking for?
Thanks.
89 Formula, Maui Blue,355 TPI(used to be TBI) Auto, TES, 3" dynomax Hi-Flow cat, 3"Flowmaster single in, single out cat back. B&M shift kit, afpr.
89 Formula, Black, with really bad paint, 305 TPI Auto, t-tops bone stock (so far)
Old Dec 16, 2000 | 03:15 PM
Vader's Avatar
John,
The vacuum source is a 1/8" hose fitted into the plenum vacuum port near the FPR vacuum line.
Any other significant hose leaks in the passenger compartment can do the same thing, causing all air doors to dump to the default positions (out the defrosters).
If the line is intact, you might have a problem with the rotary vacumm valve in the heater control console itself. After several years, the silicone grease on the ported valve halves tends to dry out and get displaced. If you find this to be the case, clean off all the grease from the valve halves. Apply a fresh layer of dielectric silicone grease (Permatex item) to both halves and reassemble it. This usually seals the device for another ten years or so.
Later,
Vader
"No matter how hard you try you can't stop us now"
Adobe Acrobat Reader 4.0
Old Dec 16, 2000 | 03:16 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
EDIT: Doh!! Vader beat me by a minute!!
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
GO #3
[This message has been edited by Engineboy (edited December 16, 2000).]
Frozer!!!
Jan 19, 2024 04:55 PM
sweet_87_iroc
Exterior Parts for Sale
Mar 27, 2016 04:05 PM
1985chevydude
Aug 22, 2015 05:36 AM
redmaroz
Aug 16, 2015 11:40 PM
Cheibu70
Interior Parts Wanted
Aug 15, 2015 12:11 PM
