Intermitant no start problem
Old Dec 16, 2000 | 03:14 PM
John 89 Formula's Avatar
Car: 89 FORMULA FIREBIRD, 86 CHEVY CAMARO
Engine: L98, LB9 RESPECTIVLY
Transmission: 700 R4 (BOTH)
Ok guys, here is a weird one, every now and then I'll try to start the car, it will crank just fine, but it acts like it is getting no spark or gas, I'll let it sit 10 or 20 minutes and then it will start like there wasn't ever a problem. Could this be a VATS related issue?
I have this problem with both cars ( check sig)
89 Formula, Maui Blue,355 TPI(used to be TBI) Auto, TES, 3" dynomax Hi-Flow cat, 3"Flowmaster single in, single out cat back. B&M shift kit, afpr.
89 Formula, Black, with really bad paint, 305 TPI Auto, t-tops bone stock (so far)
Old Dec 16, 2000 | 03:18 PM
Vader's Avatar
John,
I'm not certain about the earlier VATS systems, but I think it wouldn't even crank if the VATS was in lockout. As I said, I'm not certain of this.
It wouldn't hurt to clean the keys and contacts in the ignition switch, however. And DON'T use any oils/fluids on the ignition switch lock cylinder (or any other locks, for that matter). Graphite only.
Later,
Vader
"No matter how hard you try you can't stop us now"
Adobe Acrobat Reader 4.0
Old Dec 16, 2000 | 03:25 PM
Now that you mention it, you are right about the no cranking,several years ago someone tried to steal the car, when the actuator rod was pulled by hand the car would not crank unless the key was in the lock.
Thanks for the info on both questions
I'll try to clean the rotary fitting and see what happens.
92camaroJoe
Jul 29, 2023 07:57 PM
Infested
May 22, 2018 11:56 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
92camaroJoe
Aug 13, 2015 06:07 AM
mustangman65_79
Aug 8, 2015 12:07 PM
