Injection systems
Old Dec 16, 2000 | 09:54 PM
92RS shearn's Avatar
Car: 92' RS
Engine: LO3
Transmission: Probuilt 700R4
Axle/Gears: 3.70 9-bolt
Injection systems
OK, I've heard of TBI, I've heard of TPI, CFI and MPFI, but what in the world id PFI? My dad got an 92 DeVille woth a 4.9 V8 with PFI injection. FWD She moves though i'll tell you that
Flowmaster,Edelbrock open filliment filter with K&N filter in it
160 stat,
Old Dec 16, 2000 | 09:58 PM
Vader's Avatar
92,
Port Fuel Injection is virtually the same as MPFI and TPI. Fuel is sprayed directly into the intake port, right behind the intake valve.
Later,
Vader
"No matter how hard you try you can't stop us now"
Adobe Acrobat Reader 4.0
Old Dec 16, 2000 | 10:01 PM
Car: 92' RS
Engine: LO3
Cool,Tannks Vader
160 stat,
Old Dec 16, 2000 | 10:03 PM
Vader's Avatar
By the way, there is also a CPFI system - Central Port Fuel Injection. It is somewhat of a hybrid TBI system, but has he injectors scattered in the manifold after the throttle body.
SFI - Sequential Fuel Injection is much like any other port injection system, except that instead of batch-firing the injectors (in groups) each injector is opened in sequence. the improved timing makes for more accurate fuel metering and results in lower emissions, better efficiency, and more power.
Later,
Vader
Old Dec 16, 2000 | 10:53 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Vader, in '96 it actually became a CSPFI becuase instead of earlier versions where there was one injector and six poppets with a batch fire, there were six injectors with each one having its own poppet nozzle, and was fired sequentialy. This was used on the '96 and later Blazer/Jimmy/S10/Sonoma w/ 4.3L and the C/K series trucks and Sport Utes with 4.3/5.0/5.7. All of these were called "Vortec" engines. But now that GM uses GenIII engines in the C/K trucks, the 4.3L in the S/T trucks is all that is left with the CSPFI.
As for the Caddy, the intake looks like it has TBI, but is has a dry intake with one injector in each intake track instead of the throttle body.
If you live in Southeastern US, check us out!
South East Thirdgen
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey, 22# injectors,
JET AFPR, Ported Plenum,
TB Coolant Bypass,
SSM SFC, Boxed LCAs,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
KYB Shocks
-->14.97 @ 94.9 MPH<--
'97 Bonneville SSE
Old Dec 16, 2000 | 10:59 PM
Vader's Avatar
GMT,
Good to hear you're still hanging in there. Thanks for the clarification. All we need is one more acronym for EFI systems and we'll have to write a service manual supplement just to interpret the names and acronyms.
We could call it "GM Electronic Fuel Injection / Special High-Intensity Training". If we only had an acronym for the title....
Later,
Vader
Old Dec 17, 2000 | 02:31 AM
Black Beauty's Avatar
Car: 90 Camaro RS
Engine: 305 TBI
what about DFI...digital fuel injection
Rick
90 Camaro RS 305 TBI
400 small block, Hooker 1 3/4 LTs, Random Tech Cat, Hooker aero chamber cat back on the way!!
TH700-R4 with Trans-Go shift kit (corvette servo here...but not installed yet)
MacEwen Motorsports White Gauge Overlays
14" K&N X-Stream Open Element
GTS Headlight and Taillight covers
5% Limo Tint all around
Classic White Chevy Bowtie sticker on rear window
http://www.geocities.com/esvalenz
Man if my camaro were a rice-rocket all those mods would give me what...easily 50-60 hp!!!
"Just because I've done it, doesn't mean I knew what I was doing!" - Me
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
racereese
Oct 10, 2015 09:39 PM
customblackbird
Oct 1, 2015 04:30 PM
aharvel50
Sep 21, 2015 07:31 PM
