SUCCESS!! Torx is no more...literally
Old Dec 17, 2000 | 02:42 AM
I ROCK's Avatar
Car: 89 IROC-Z
Engine: LB9
Transmission: 700-R4
Well absolutely NO little tricks or shortcuts worked...I used two carbide cutting bits to completely grind the heads off those d*** bolts. Thanks to everyone for your ideas! The ROC seems like it will live. If I had to do it again I would've bought four of those bits...steel is pretty tough. Now I live in the wonderful world of hex heads and anti-seize. Thanks again guys...by the way, what would a machine shop charge to port my intake manifold since they'll be heli-coiling a thermo bolt hole anyway? Thanks.
89 Iroc-Z LB9 305 TPI auto 2.73 posi:
3" Dynomax "cat" back,K&N filters, TB bypass, 3" pipe in place of cat, cleaned and flow-matched injectors, 170' thermo, mild ignition mods, synthetic oil, kicker sound system, soon to have 3.73 posi...
Old Dec 17, 2000 | 08:39 AM
ede's Avatar
ede
glad to hear you got it out. stuck bolts suck.
ICON Motorsports
1st & 3rd
Old Dec 17, 2000 | 12:19 PM
Vader's Avatar
U ROCK,
You know, you can install a thread insert in your intake without removing it from the engine. There are several types, either Heli-Coil or captive inserts with stakes. Either one can be installed with only a drill and tap, and the chips generated can be vacuumed out of the coolant passage crossover.
As far as porting the intake, you might have a tough time finding a general machine shop that performs that kind of work. Since much of that is pretty experimental for most shops, you'll have to find a specialty speed shop that will undertake the project and then expect to pay for it. If you can find a die grinder in your tool box and a new pair of intake gaskets as templates, you can spend some time and save a little cash, all while learning something about air flows.
Later,
Vader
"No matter how hard you try you can't stop us now"
Adobe Acrobat Reader 4.0
Elephantismo
Feb 13, 2019 12:51 AM
Fronzizzle
Feb 9, 2017 09:31 AM
C409
Jan 21, 2016 08:29 PM
James Sutton
Sep 23, 2015 01:56 PM
Hawkeye1980
Aug 31, 2015 07:09 AM
