1.5 or 1.6 rockers with vortec heads?
Car: 1991 Camaro Z28 5.7 G92
Engine: L98 Tuned Port Injection
Transmission: TH700R4
Axle/Gears: 3.23 Posi G80
I have 1.5 aluminum roller rockers and vortec heads with all the proper machining and valve spring work. My question is should I change to 1.6 rockers? I am using the HOT cam and I know that it was designed for 1.6's but the stock ports on vortecs flow the best around .500 and lift with 1.5 is right at .492. The desktop dyno showed only a 2 hp increase with 1.6's, the 2 hp and hardly seems worth the change and the shorter valvespring life.
Do you guys think that there would be a bigger gain in real life?
84z96L31vortec
Aug 20, 2017 12:16 AM
L98GTA87
Aug 11, 2015 06:55 PM
