305 heads on a 400
Old Nov 6, 2003 | 09:39 PM
Duke901's Avatar
Car: 89 Formula
305 heads on a 400
I have a 400 that has no heads but I have a pair of 1985 TPI 305 heads laying around. Would I be able to use them on the 400 if I had the holes drilled for the steam ports? Also how much would that raise the compression.
Thank you
Old Nov 6, 2003 | 11:08 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
Yes you can use them on a 400SB after drilling for the steam holes.
The nominal chamber size on those heads is 58cc's
To calculate your compression ratio with thoses heads you need to tell us a bit more about the 400.
Piston dome/ dish volume valve relief volume, piston deck clearance at TDC.
Old Nov 7, 2003 | 02:59 AM
Morley's Avatar
Those heads will over hang the cylinders horribly. The 305 has a bore of, what? 3.766" and the 400 has a bore of 4.125" leaving 0.359" of head surface over hanging the cylinder bores. And getting gaskets to seal properly may be a problem.
Old Nov 7, 2003 | 04:17 AM
kfoley's Avatar
Car: '85 Z28
Transmission: WC T5, 3.23 posi
Just did a quick calc and compression would be at 11.7:1 w/ a set of FT's. A -18cc dished piston would be required to get a pump gas friendly 10:1. Both those are with a .041" think headgasket and 9.025" deck height.
Jake_92RS
Jan 28, 2020 10:37 PM
camaro71633
Sep 1, 2015 10:24 AM
lakeffect2
Aug 23, 2015 08:44 AM
theurge
Aug 21, 2015 12:46 PM
