carb aircleaner question.. cleaner size Vs spacers?
Old Nov 7, 2003 | 12:55 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
has anyone done any conclusive back to back testing on aircleaner size Vs spacers?
im mostly talking about highrise carb intakes...
i see some guys running a 1" spacer and then only having a Drop base air cleaner....
what usually makes more power? having no spacer and a bigger air cleaner, or having the spacer and a smaller or dropbase aircleaner?
anyone do any back to back testing? does it just vari alot depending on engine?
Old Nov 8, 2003 | 09:33 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
anyone?....... anyone?
bueller?.............. bueller?
Old Nov 8, 2003 | 09:41 AM
rhuarc31's Avatar
Car: 89 Formula 350
Engine: 409 nitrous' small block
Yeah, car craft or hot rod did one like 6 months ago or so. The short answer is that they found that drop base air cleaners didn't really hurt flow and spacers helped. In a couple cases they found that the drop base air cleaner actually flowed better. Needless to say they were suprised because common belief is that drop base aircleaners hurt flow. So if you're debating weather to run a spacer with a drop base cleaner, or a low rise with a regular, go ahead and run the high rise you're not gonna hurt anything, and you'll probably gain a couple ponies.
Old Nov 8, 2003 | 10:16 AM
25THRSS's Avatar
the spacer will give a little more plenum volume. Unless the filter isn't allowing enough air flow it won't help anything so I would go with a spacer over the huge filter.
Old Nov 10, 2003 | 02:01 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
did a search and finally found the artical you were talking about
http://www.carcraft.com/techarticles/51980/index.html
just incase anyone ever comes across this thread and is looking for the info.
Old Nov 10, 2003 | 02:13 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
[ONly if you watch to much TV]
Don't forget Big Daddy Don Garletts tip of the week.
a 1 1/2 - 2 in spacer is a great way to increase power for free.
Course what a broad statement but just thought I would share.He was from the day of stick it on and run, no math involved.
Matt
Old Nov 10, 2003 | 09:33 PM
25THRSS's Avatar
Thats a pretty cool article, but I didnt even know it existed, lol. Thanks for the link.
toronto formula
Nov 10, 2015 06:17 AM
Streetstuff
Carburetors
Sep 7, 2015 02:33 PM
86IROC112
Aug 17, 2015 02:00 PM
wruiz
Aug 13, 2015 09:07 PM
knight72
Aug 10, 2015 09:32 PM
