OIL PRESSURE
Old Dec 18, 2000 | 01:09 AM
CAMARO-90-RS's Avatar
OIL PRESSURE
I WANTED TO KNOW IF IT IS NORMAL FOR THE OIL GUAGE IN THE INSTRUMENT PANNEL TO GO OVER THE LIMIT WHENEVER ONE ACCELERATES
Old Dec 18, 2000 | 01:25 AM
JP84Z430HP's Avatar
Car: 84 Z28
Engine: 355 (fastburn heads, LT4 HOT cam)
Axle/Gears: 9-bolt, 3.27
I have seen those things do lots of weird things! Reading higher than the actual pressure is one! If you're concerned, check it with a mechanical gauge.
Working on:
'84 Z28 LG4 305
Added dual elec fans.
145 MPH IROC Speedo
Building 430 HP 350
using primarily GMPP parts.
Block is in shop!
Awaiting results from all 8 ASE tests.
Starting to look like the Kicker poster child!
Old Dec 18, 2000 | 01:27 AM
I ROCK's Avatar
Car: 89 IROC-Z
Engine: LB9
Transmission: 700-R4
There is no real limit. Usually, the higher the better until you start to get leaks. When you accelerate the pressure will rise a little and that's fine. Unless it's leaking or there's other drivability problems it's fine.
89 Iroc-Z LB9 305 TPI auto 2.73 posi:
3" Dynomax "cat" back,K&N filters, TB bypass, 3" pipe in place of cat, cleaned and flow-matched injectors, 170' thermo, mild ignition mods, synthetic oil, kicker sound system, soon to have 3.73 posi...
83 Crossfire TA
Jan 3, 2016 01:26 PM
angel2794
Sep 8, 2015 06:22 PM
Strick1
Sep 4, 2015 07:11 AM
solocus
Sep 2, 2015 12:14 PM
