Questions about small plastic vacuum lines that hook to coil bracket for TPI...
Old Dec 17, 2000 | 10:52 PM
I ROCK's Avatar
Car: 89 IROC-Z
Engine: LB9
Transmission: 700-R4
Well I broke one of those so I'll need to go buy some more. Also, I don't recall the exact routing of them - I've got cruise and A/C if that matters. Also, does the pcv hose on the driver's side hook up to the plenum or the manifold? If it's the plenum, what's the fitting in approximately that location on the manifold for? Thanks for any help.
89 Iroc-Z LB9 305 TPI auto 2.73 posi:
3" Dynomax "cat" back,K&N filters, TB bypass, 3" pipe in place of cat, cleaned and flow-matched injectors, 170' thermo, mild ignition mods, synthetic oil, kicker sound system, soon to have 3.73 posi...
Old Dec 18, 2000 | 12:18 AM
Omar's Avatar
That is the EGR solenoid that is sitting near your coil. One line goes to the EGR valve, and the other connects underneath the throttle body. The PCV valve on the driver side goes to the intake manifold.
1989 IROC-Z 5.7L
Old Dec 18, 2000 | 12:21 AM
I ROCK's Avatar
Car: 89 IROC-Z
Engine: LB9
Thanks a lot man! Do you know where I can buy these lines?
Old Dec 18, 2000 | 01:15 AM
Vader's Avatar
U ROCK,
Apparently, everyone has trouble finding the material to make these lines except me. They are a hard nylon tubing, thermoformed to the contours required. You can get this at most local industrial suppliers in sizes from 1/8" to 1/2" O.D. It's available in white, black, yellow, red, green, and blue, and probably other colors if you look harder.
It can be heated and bent to form whatever shapes and bends you might want. It costs about 15¢ per foot. Ask for Coilhose nylon tubing at your local distributors, or order what you want through McMaster.com or MSCdirect.com
Later,
Vader
"No matter how hard you try you can't stop us now"
Adobe Acrobat Reader 4.0
Old Dec 18, 2000 | 01:25 AM
I ROCK's Avatar
Car: 89 IROC-Z
Engine: LB9
Thanks again...hopefully the ROC will be up and running soon with all this great advice. The only reason I even answer questions on here is just to save you and ede and others time! You're in norther IL right? I'm in the South Bend area of Indiana but I didn't make the Chitown gathering in June unfortunately. Well time to get to work! Later
Old Dec 18, 2000 | 01:32 AM
JP84Z430HP's Avatar
Car: 84 Z28
Engine: 355 (fastburn heads, LT4 HOT cam)
Axle/Gears: 9-bolt, 3.27
What are the typical sizes needed? I know there are 2 sizes, and they seem to be 1/8" and 1/4". Am I right? I usually repair these with a piece of rubber vacuum line and some rubber cement to splice them.
Working on:
'84 Z28 LG4 305
Added dual elec fans.
145 MPH IROC Speedo
Building 430 HP 350
using primarily GMPP parts.
Block is in shop!
Awaiting results from all 8 ASE tests.
Starting to look like the Kicker poster child!
Old Dec 18, 2000 | 01:37 AM
Vader's Avatar
JP,
I think you're right. Most sizes of the nylon are a ¼" or under. I have to use rubber cement at the ends as well, but I'm partial to the "racing red" nylon instead of the boring old black rubber. The nylon is supposed to be good for pressure or vacuum ut to 250°. Since there's almost no pressure or vacuum, the operating tempeature is even higher. That's probably why the factory chose to use it in the higher heat areas under the hood, like the EGR lines stuffed under the plenum.
Later,
Vader
1992 Trans Am
May 10, 2023 07:19 PM
theshackle
Mar 5, 2017 06:37 PM
Fast355
Dec 2, 2016 06:33 PM
redmaroz
Aug 16, 2015 11:40 PM
apie2546
Aug 10, 2015 05:43 PM
