What is my compression Ratio?
Old Nov 7, 2003 | 10:35 PM
Johnny Blaze's Avatar
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
1988 350 L98 stock shortblock. Had stock cast iron heads milled .020" . Using a felpro preflattened head gasket with a thickness of .015" Which adds 3.2cc to the chamber. What is my compression ratio? The chambers on the heads have not been touched.
Old Nov 8, 2003 | 07:30 AM
Car: 1971 Camaro
Engine: 427
Stock is 9.3:1 right? Anyonw know the thickness of the stock head gasket? I would think it is thicker than the .015" one I am using now. How much would .020" milling of the head increase it?
Old Nov 8, 2003 | 12:01 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
I'am running Brodix street heads on my GTA. Brodix says that for every .006" flat milled you loose 1 CC for the steet heads. It has been my understanding that for every 1CC you gain or loose .1 in compression in our L98 350CI engines. Not sure if this can be directly applied to your situation but will give you an idea. Allen
InfernalVortex
Apr 20, 2021 11:31 AM
FormulasOnly
Jul 23, 2018 08:47 AM
Vincent135
Sep 28, 2015 10:50 PM
Damon
Sep 26, 2015 04:29 PM
83 Crossfire TA
Sep 8, 2015 12:06 PM
