done with heads,,,hear slight tick
Old Nov 8, 2003 | 09:38 AM
llvll4l2c91350's Avatar
i adjusted the valves by bringing each cylinder up to TDC, moving the pushrods up and down until there was no play, then half a turn more. going thru the firing order. car has been running fine without any problems. but i hear a slight tick coming from the passenger side. my q is, if the valves were misadjusted how lould would the noise be?? on mine it's not loud at all (sounds like injector tick) but it does sound like one could be ouy. i took it to the guy who did the heads and he said it's nothing to worry about. if the valves were off they'd be noticeably louder.
also when i started it the first time i filled it up with water thru the lower radiator hose. i thought once it started running the water would fill the block. i started the car but the water didnt go down. so it ran for about 30 seconds with an empty block. is this any cause for concern?
Old Nov 8, 2003 | 03:24 PM
ede's Avatar
ede
might want to recheck the rocker nuts and look for an exhaust leak. i wouldn't worry about the lack of water
Old Nov 9, 2003 | 06:12 PM
took care of the noise. i adjusted the valves with the engine running. wasn't as messy as i thought it would be.
db057
Sep 4, 2015 07:57 AM
NinjaNife
Aug 23, 2015 11:49 AM
db057
Aug 22, 2015 08:17 PM
redmaroz
Aug 16, 2015 11:40 PM
