Hard cam question, seriously....
Old Dec 18, 2000 | 11:11 AM
Macgyver's Avatar
What's the intake centerline of an LT-1 350 mechanical lifter cam?
Here's the rest of the specs:
LSA 166
lift@.050
.435
.455
Duration:
242
254
I'd like to know the correct intake center line in crank degrees so I can do a semi-accurate DD2K run.
Shane McConnell
macgyver@nethirdgen.org [*]Webmaster of www.NEThirdgen.org[*]1991 RS 305 T5 15.6@88[*]1979 Z28 ZZ4/2004R (In the future.)
I'm the kinda guy you bring home to Mother.
Old Dec 18, 2000 | 02:22 PM
ws6transam's Avatar
Car: 1984 Trans Am WS6
Engine: Minirammed 385, 396 RWHP
Axle/Gears: 3.73 Moser 12-bolt
LSA 166
Dang! That's one heck of a lobe separation!! Darned near on the opposite side of the bumpstick!
Old Dec 18, 2000 | 03:04 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
I believe you can get that off Comp's page of cam specs, in the list of the factory replacement cams... www.compcams.com then go to the cam spec cards.
Why on earth would anybody want to use that cam for anything? It was a terrible cam. Too much duration and not enough lift. The 754 OTC replacement racing cam for that application was a far better piece, for that matter even the old so-called 324°/324° .485"/.485" (302 optional) Z-28 cam would be better for a modern motor especially with 1.6 rockers. I hope all you're doing is comparing DD #s to the factory's "as-built" specs!
Old Dec 18, 2000 | 05:13 PM
stingerssx's Avatar
Car: '88 Firebird Formula 350
Engine: Built 383 TPI
Transmission: Built 700r4
Axle/Gears: 9 bolt, 3.27:1 Posi
I'm sure the specs for the duration are "advertised" and not @ .050"
'82 Firebird, dead stock, 9 bolt disc rear, over 200,000 miles and still going strong, more to come...
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
Fronzizzle
Aug 9, 2015 01:15 PM
