quick wiring question about VATS
Old Nov 9, 2003 | 12:18 PM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
Transmission: 700r4, 2200-2400 stall, vette servo
Axle/Gears: stock pegleg 2.73 drum (temp)
since I don't have access to a chilton or haynes right now, I need to know which pair of wires is the VATS connection. I need to bypass it so I can start my car!
thanks a lot
Old Nov 9, 2003 | 05:56 PM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
92 L03 if its anything that matters
Old Nov 9, 2003 | 06:05 PM
onebinky's Avatar
It will be 2 wires coming down the bottom side of the column, usually in a white jacket. There will be a plug about 1/2 way down, you'll want to cut the wires after the plug and solder in your resistor. I think the wires are purple and white, but it's been a while...
EDIT: Don't touch the yellow jacket pair of wires, unless you want the airbag in your face
Old Nov 9, 2003 | 07:06 PM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
awesome
I'm too drunk now to work on my car, but maybe tomorrow after school!
Old Nov 9, 2003 | 09:06 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Hey Token, save some for the rest of us! But anyway, the wires coming from the steering column will be white with an orange wrap. The wires they plug into will be purple/yellow and black/white. These go to the VATS control module and are the ones you want to jumper with the resistor. Good luck!!!!!!!!!!!!
The Trickster!!!!!!!!!!!!
Old Nov 10, 2003 | 06:03 AM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
awesome, thanks. let's hope this fixes the problem!
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
stalkier
Aug 13, 2015 12:59 PM
djmarch
Aug 9, 2015 05:27 PM
