Anybody here who knows Vette's
Old Dec 18, 2000 | 07:38 PM
Mike89GTA's Avatar
I was thinking of selling my GTA and getting a 92+ Corvette, the ones that look more modern and have the LT1. How hard would it be to get my L98 to work in one of those? It wouldn't be THAT hard, right?
Mike89GTA
4 bolt 350, 10.4:1 Compression, Edelbrock Aluminum Heads 6085, LT4 Hot Cam /w 1.6 full rollers (Crane), Scat Crank, SLP 1 3/4" Headers, SLP Cold Air Intake, Crane AFPR, 48mm TB, ported plenum, stock runners, Accel Super Ram intake manifold, 95Z #24 injectors, stock fuel rails, T5 Tranny, 3.45s, 9 bolt rear, 4 wheel discs, BFG Comp T/As rear, SZ50s in front, Alston SFCs, ES Trans Mount, ES front A-arm bushings, ES front sway bar end links
Old Dec 18, 2000 | 07:47 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
A 90/91 Vette would be the easiest as it already has the ecm and wiring harness. Just swap your 350 in and wire it up.
Later years will require you to swap the ecm and harness to swap your 350 in. And if it has the newer electronic auto....
Old Dec 18, 2000 | 07:52 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
I don't think it would really be that hard but, why? the 92 vett will use obdI so most of the stuff could just be put on your tpi with out a problem map, mass,tps, cts so on some like your iac may need to be spliced to work but if you do it right no one would no the diff.
Old Dec 18, 2000 | 08:38 PM
blak92!'s Avatar
1991-1996 is the same body style!
1991 Corvettes have that "modern" rounded back end and wrap around lights. Also, this was the first year of the "new look" and the last year for the L98 TPI.
Check out this link: http://www.vettepics.com
[This message has been edited by blak92! (edited December 18, 2000).]
Old Dec 18, 2000 | 08:49 PM
Mike89GTA's Avatar
wow, cool that is good news. Then it would be fairly easy to convert over.
Old Dec 19, 2000 | 02:15 PM
84FTA's Avatar
I'm assuming it should be a direct swap because the l98 was in the 91 which looks just like the LT1 corvettes. I doubt they changed the inside (as in location of the firewall). I know if 4th gens inorder to put in a regular SBC you have to cut some of the firewall out for valve cover clearences. Possibly the distrib too but the one I saw was using crank trigger ign.
One of the reasons of redesigning the SBC was so they could give it a lower profile and thus a more "modern" look.
1984 WS6 Trans Am Hartop
Former L69 Car under restoration
1984 WS6 Trans Am T-top car
4-bolt main 350, headers, Holley 650, T-5 and 3.23's.
Daily driver and restoration
FormulasOnly
Jul 23, 2018 08:47 AM
BDR
Nov 7, 2015 03:05 PM
R13_Braz
Sep 18, 2015 05:00 PM
WickedBowtie
Members Camaros
Sep 17, 2015 09:13 AM
WickedBowtie
Sep 11, 2015 11:24 PM
