Mechanical AND elecric pumps???
Old Dec 18, 2000 | 08:52 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
I'm working on a 87 Camaro (305/carb) and I noticed that it has a mechanical pump on it and an electric pump in the tank.
I've never seen both on one car. (stock) Of course I've never looked before either.
Is this normal??
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
GO #3
Old Dec 18, 2000 | 09:04 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
I have heard of such things though I have never actually seen one. It was probably done so the factory didn't have to stock 2 different part #s of gas tanks.
Old Dec 19, 2000 | 06:03 AM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
It is called a "lift" pump, and diesels have them also the feed the injection pump. Prior to '87 (so I hear) only L69 motors had them, but in '87 (last year for the carb), all the carbed engines got them. If you pull it out, you will notice that its half the size of a regular pump.
If you live in Southeastern US, check us out!
South East Thirdgen
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey, 22# injectors,
JET AFPR, Ported Plenum,
TB Coolant Bypass,
SSM SFC, Boxed LCAs,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
KYB Shocks
-->14.97 @ 94.9 MPH<--
'97 Bonneville SSE
Old Dec 19, 2000 | 07:37 AM
Engineboy's Avatar
Car: yep
Engine: uhuh
Cool.
The cust. complaint was that they hear this noise that they never heard before after they shut the car off.
I learned something today.
1999 NBM Trans Am
1981 corvette
1995 Kawi ZX6R
GO #3
Old Dec 19, 2000 | 01:32 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Once in a while I'll hear my fuel pump run for a few seconds after I shut the car off.. maybe it has something to do with oil pressure that's still high enough to run the pump? I know in this cold, my mechanical oil pressure gauge will drop slowly enough to still stay high for a second or two after I shut the car off.
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Old Dec 19, 2000 | 03:12 PM
Damon's Avatar
I sure learned something today, too. I never would have guessed.
RazorN8
Jan 7, 2022 11:44 AM
Infested
May 22, 2018 11:56 PM
theshackle
Mar 5, 2017 06:37 PM
gta90
Sep 15, 2015 04:00 PM
fbirdroller
Sep 2, 2015 10:27 PM
