Freshening up My 350
Old Nov 10, 2003 | 02:05 PM
SkullLeader's Avatar
Car: '87 Iroc Z
Engine: TPI 305
Transmission: Manual
I will be pulling the sbc 350 from my 83z so I can have the car painted, & I was wondering what could I do to it while it is out of the car to freshen it up abit without getting anything machined? Also I want to paint the engine and need some advice about prepping it for paint?
Thanks,
Skull
Old Nov 10, 2003 | 03:10 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
Just check for small leaks.... like the oil pan gasket, timing cover, valve covers, etc.
R&R as needed.
I suppose you could step up to a larger cam (within reason), better intake, maybe even just replace the timing chain set if you want.
About the only other thing would be valve seals if need be. They're MUCH easier to do with the engine out.
Old Nov 10, 2003 | 03:46 PM
SweetS10v8's Avatar
Car: '89 Formula 350 & '86 Z28
Engine: L98 & 355ci
Transmission: 700r4 in both
If you wanted to take it a step farther you could pretty much rebuild it, new gaskets, seals, bearings, and piston rings. That would allow you to take apart to check for excess wear everywhere.
I would definatly put in a new oil pump and timing chain. And like said before, this is the perfect time for a cam swap, if there is ever going to be one!!
Old Nov 10, 2003 | 06:25 PM
pvt num 11's Avatar
Car: 1989 TTA
Engine: LC2
Transmission: Worn-out 200R4
Axle/Gears: BW 9-bolt, 3.27's
Sure wish I had a garage...
If only I had the chance to do stuff like that - apartments are the pits. Someday, I'll have a house with a four-car garage, grease pit, full set of Snap-On tools, air compressor, half-ton crane...
Old Nov 10, 2003 | 06:35 PM
Spectre's Avatar
Car: Camaro Z281991 Engine: 5.7L/350 TPI Transmission: TH700R4 ··································· Car: Acura CL 1998
Engine: 3.0L/183
Transmission: 4 spd auto/OD
--without getting anything machined?
prep the block, and repaint it with por-15
what does it have already ?
if it doesnt.. id get an alum.. intake.. anything bolt on u can afford.
headers.. better alt.. etc ..
Old Nov 10, 2003 | 09:57 PM
robertg's Avatar
Car: 2000 astro
Engine: 4.3
Transmission: A4
Axle/Gears: 7.5 with 3.42 gears
i'm going to be pulling the 305 from my coupe soon. while it's out, i'm replacing the oilpan gasket with a 1 piece unit. i also want to check over the other parts, and possibly put new valve seals on the heads. it smokes prety bad on startup.
TX-SleeperC5
Feb 24, 2016 01:34 PM
89fast5oh
Sep 8, 2015 09:55 AM
john204481
Sep 7, 2015 03:22 PM
FtrSpeedy
Sep 7, 2015 12:11 PM
Formula_88AE
Sep 3, 2015 01:47 PM
