bolt on HP?????
Old Dec 17, 2000 | 02:25 PM
bigbird88's Avatar
bolt on HP?????
Hey need more speed! Have a 88 TA 305 what kind of bolt on aftermarket parts will give me the most hp for the price??
Old Dec 17, 2000 | 05:22 PM
R.O.B.'s Avatar
Start with the exhaust. No matter what you do, this is the biggest restriction.
Rob
'86 TA 305 TPI
Old Dec 17, 2000 | 08:31 PM
bigbird88's Avatar
Flow master good choice?? cat back system??
Old Dec 17, 2000 | 09:54 PM
bad@ss92camaro's Avatar
k@n filter
92 camaro 25th anniversarry polo green with 2 gold stripes stock 305 tbi
89 camaro
white
92 ground effects
cowl induction hood
tinted windows
accell plug wires
K@N filter
305 from 92 camaro
carburated
bored .030
flat top pistons
larger valves
zz4 cam
heads shaved
Old Dec 18, 2000 | 11:19 AM
IrocManiac's Avatar
Start with the exhaust. I have my flows in the mail as I type this. K&N airfilters and go with a tpi airfoil if you are a tpi car. Custom chips are always good too and not too expensive.
TPI 305,
Gutted airboxes,
gutted MAF,
K&N filters,
Corvette Servo.
14.9@93mph
"Speed kills, wanna live forever, drive a Ford."
Old Dec 19, 2000 | 06:07 PM
bigbird88's Avatar
Where is the best place to get these parts???
Old Dec 19, 2000 | 06:43 PM
Stell1579's Avatar
i have doen the MSD 6A + accell coil slp airfoil, ported the intake plenum, k&n and the thermostat and fan switches
now bigest gain i noticed was when i did the 6A and the coil. it had mutch more response and pulled harder past 3K. now that cost me about 200 bucks all togeather (did wires cap and rotor too)
next big inmrovement was the ported plenum. gave a little more throttle response.
as for upping th ehorsepower well i dont know but lemme tell ya i **** on my dad's 88 TA with the same engine and a 3.08:1 rear (mine is 2.73:1).
k&N realy no inprovement just a good reusable filter, airfoil made it pull a little smoother thats about it.
now when everyone said the exaust was a huge restriction i think they didnot bean from the cat back (although a good system will help) i think it was directed more tward the manifolds. they are the most restrictive i have ever seen and everyone who changes them to the emissions legal headers says there is a huge inprovement.
the only bad part is the price if you want to stay 50 state legal. edelbrock and hooker make a set for around $$350 and from what i have heard SLP's set is stainless steel and cousts upwards of $$500. i personaly am gonna get the hooker ones come this summer.
places to find stuff
www.jegs.com www.summitracing.com www.slponline.com www.ebaymotors.com www.tpis.com www.fastchip.com
now i see your new to the board, look around and read asmany posts as you can, you will learn alot about these cars as i have (knew nothing when i made my first post witch was similar to yours).
and if your not to sure of yourself when it comes to working on these cars, (dont take as an insult, i donot know your level of knolege with cars) do a real good tuneup
plugs,coolant,hoses,oil/filter, cap+rotor, ignition wires, pcv valve, fuel filter.
also check out the tech articles on the main page
good luck
-Stell
1988 IROC 305TPI MINT!!
Mods= Accell SuperCoil, MSD 6A, Ported Plenum, No MAF Screans , K & N, 160 Thermostat+ Temp Switch, Relocated MAT, Cold Air
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
Numbah-1
Sep 12, 2015 08:57 PM
Jlanz55
Sep 6, 2015 07:28 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
