Cruise control still broke
Old Nov 11, 2003 | 08:42 PM
Maui 88's Avatar
Car: 88 Camaro, Maui blue with grey ground effects
Engine: LB8 V6, but building a 350
Transmission: 5 speed manual
Ok, my cruise switch was broke so I replaced it, and it worked for a week, now something else in the cruise control system isnt working. I put the switch on another Camaro and it worked, so it isnt the switch. What else could it be? How do I go about fixing it?
Old Nov 11, 2003 | 09:14 PM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
Transmission: 700r4, 2200-2400 stall, vette servo
Axle/Gears: stock pegleg 2.73 drum (temp)
make sure the mechanical link is connected
Old Nov 13, 2003 | 09:23 PM
holov1's Avatar
Car: 89 formula 350
Engine: L98(350)
how about the switch on the brake pedal ?
Old Nov 13, 2003 | 09:36 PM
Maui 88's Avatar
Now my cruise all of a sudden works, but it sometimes turns off for no reason. I guess I can live with that.
Old Nov 14, 2003 | 10:07 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Have you checked the cruise control module under the dash on the passenger side?
The Trickster!!!!!!!!!!!!!
Old Nov 15, 2003 | 06:53 PM
holov1's Avatar
Car: 89 formula 350
Engine: L98(350)
when it doesn't work try putting your foot behind the brake pedal and pull up if it works then . the brake switch is either out of adjustment or is going bad and needs replaced
wigmobile
Feb 26, 2025 02:56 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
DiabloWS6
Southern California Area
Feb 15, 2016 02:08 AM
DiabloWS6
20
Dec 11, 2015 04:12 PM
scottmoyer
Sep 7, 2015 07:06 PM
