Won't start, will crank, fan runs/temp up?
Old Nov 12, 2003 | 08:41 AM
macvtm68's Avatar
Car: 1992 camaro
Engine: 3.1
1992 camaro with 3.1 died suddenly. Engine will crank but not start. When I turn the key to the on position the radiator fan immediately runs and the temperature guage will zoom to and lock in at the highest temp even though the engine is cold. I don't seem to have spark at the plugs; coil and wires are new. I tried starting with the fan relay and temp sending units disconnected but still no start. It is almost as if there is some sensor that says the engine temp. is way over specs. shut the system down? Any ideas appreciated.
Old Nov 14, 2003 | 08:09 AM
macvtm68's Avatar
Car: 1992 camaro
Engine: 3.1
The problem turned out to be a bad ignition module. I still do not know why it would have such an effect on the radiator fan and temperature guage? Both have returned to normal?
Old Nov 14, 2003 | 09:01 AM
Quick_Trans_Am's Avatar
Car: 1985 Pontiac Trans Am
Engine: 355 with stuffs.
Axle/Gears: 4.10 Posi
I've never heard of an ignition module doing that before. If you ask me I think that the ignition switch may be on its way out as well, maybe not engaging fully. I would maybe look in to it as well.
Old Nov 15, 2003 | 03:06 AM
radiateu2's Avatar
How about a HEAT SOAKED STARTER COULD THAT BE THE PROBLEM AND AFTER IT COOLED IT STARTED UP
eightsixseven
Dec 16, 2024 01:50 PM
Caspar
Jun 19, 2016 11:19 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
Brcharrelson
Aug 26, 2015 07:47 PM
justin57
Aug 20, 2015 07:05 PM
