Nov 12, 2003 | 12:59 PM
My fuel pump seems to have died. Does anyony know where I can get a new (new) FSU so that I can just kill 2 birds with one stone (my fuel gauge has not worked for as long as I can remember. I have heard that no one makes this FSU aftermarket... any soluntions to the never functioning gas gauge?
Reply 0
Nov 12, 2003 | 01:03 PM
... a new idea... I found the fuse for the fuel pump, but does their exist a relay for the fuel pump, and if so, where is it ?
Reply 0
Nov 12, 2003 | 01:58 PM
Yeah, there is a relay on the drivers side firewall for the fuel pump. At least, there is on my 89. There should be a mount with three relays on it and If I remember correctly, the fuel pump relay is theone in the middle. I think.
Reply 0
Nov 12, 2003 | 05:48 PM
Well, i'll change that tonight and let you know how it goes.
Reply 0
Nov 12, 2003 | 10:59 PM
Can you confirm on that Fuel relay? My haynes does not note its exact location, and there are three of them (unfortunately, changing the relay that I thought would be correct did not work.
Reply 0
Nov 13, 2003 | 12:02 AM
The fuel pump relay should be in the middle. That should have nothing to do with your fuel gauge. The sending units are EXPENSIVE. I work at advance autoparts and I looked it up. 350$ for the sending unit.
I need one also...after 1/2 tank the gauge no longer works. But until I can find a cheaper one I'm just gonna have to drive it as is...I've done it for almost 2 years.
Reply 0
Nov 13, 2003 | 02:29 AM
yeah, I tried auto parts stores but they are useless, all of them around here say its discontinued, and GM wants like 350 bucks for a sender! I say just hit up a junkyard......
Reply 0
Nov 13, 2003 | 06:34 AM
You can't go wrong with a junkyard, most of the time. Thats definately your best bet....sometime Ebay even has a couple. You may alos want to check online for some aftermarkets or remans.
Reply 0
Nov 13, 2003 | 12:53 PM
Im hoping the sender on this 84 carb pickup I have works. Since Im gonna use it and run an external holley fuel pump.
If it doesnt work no big deal Im used to it.
Reply 0
Nov 14, 2003 | 01:53 AM
as long as it has a 0 - 90 ohm range, which it does
Reply 0
Subscribe
