Oil pressure gauge jumping???
Old Dec 21, 2000 | 08:04 AM
Pino91Formula's Avatar
Last night i noticed that my oil pressure guage , would jump to 60psi after it would get to about 3/4 of the way at about 40 psi , Like it was grounding out , then after a while it acted normal , i figure it might be the sending unit , or maybe the wire grounding out, anyone comeacross this before?
Thanks again for any help.
Pino
91'Formula
LB9 305 TPI 5-speed
WS6 17" wheels
Eibach Pro-Kit Springs
Hotchkiss STB
SLP exhuast
SLP Cold Air Induction
CatCo Hi Flo Cats
http://www.geocities.com/MotorCity/Garage/5654/mur91.jpg
Old Dec 21, 2000 | 09:12 AM
327 firebird's Avatar
Fist things first check your oil. It could be sloshing around in a fast stop or accelleration and when low the pump maybe sucking air causing the fluxing. If the oil is good it very well could be a ground or shorting wire. Also a bad sending unit or even the oil pump going bad.
Old Dec 21, 2000 | 09:14 AM
Oh yeah when my sending unit went bad my gauge went full up on the high side.. it didn't go low. But I don't know it still could be your sending unit
Old Dec 21, 2000 | 09:16 AM
I wasnt really driving hard , i was just cruzing, Its just real jumpy, not a smooth flo
Pino
91'Formula
LB9 305 TPI 5-speed
WS6 17" wheels
Hotchkiss STB
SLP exhuast
CatCo Hi Flo Cats
Old Dec 21, 2000 | 11:04 AM
Well in that case I don't think its your sending unit but you can try it. Its a cheap part like 10 bucks. See if it fixes it.. If not just clean it up and return it. To me it sounds more like a wire problem or your oil pump on its way out. Check the wires first because they are the easiest to do. Believe me it sucks changing an oil pump in a f-body, because of the crossmember. Also you didn't say if you checked your oil or not? Is it totally full? Always check the simplest things first.
Old Dec 21, 2000 | 11:17 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
That almost certainly is the sending unit. They're a variable resistor, with a wiper that moves on a wirewound element. When the wiper loses contact with the element the gauge reads full-scale. What you describe is a fairly common failure mode for those things. Like 327 said, it's a cheap part, so you can just troubleshoot by substitution without killing your bank account.
Old Dec 21, 2000 | 01:14 PM
Cool thanks guys , Thats what i figured it was , oil is full , car runs super , so i wouldnt think it was the pump. Ill check it this weekend , oh yeah, is the sending unit, down by the oil filter , or up top at the back of the intake? I just dont feel like digging for it in 20 degree weather.
Thanks again
mike_c
Aug 27, 2015 04:32 PM
355sbcTPI
Aug 19, 2015 04:38 PM
bamaboy0323
Aug 15, 2015 07:20 AM
ChevyZ71
Aug 13, 2015 07:30 AM
