Blown intake gasket?????
Old Dec 23, 2000 | 06:23 AM
quartermileguy's Avatar
Has anyone had this problem....
I have an 87 iroc 305, i noticed the antifreeze was disappearing so i put it up on the pit to investigate and noticed that on the rear passenger's side of the engine near the distributer was a nice river of fresh coolant. it looked like it was coming out between the intake and block, is this common/hard to fix.... i don't mind doing the work i just don't want to waste my time doning an intake gasket to find out it was something else....
quartermileguy@hotmail.com
Rob
69 Camoro -- Still restoring 10 years later almost there.....
87 Iroc just getting back into it.
Old Dec 23, 2000 | 07:58 AM
jbenge's Avatar
Car: 1991 Camaro Z28
Axle/Gears: Strange 12 Bolt, 3.42
That definately sounds like an intake gasket leak. Yes its a very common problem, I've had to replace intake manifold gaskets on several of my cars. Its not too hard to fix, just be sure to get the distributer back in correctly. Sometimes the coolent will leak up around the intake bolts too, if thats the case try putting some #2 permetex on the bolt and putting it back in. Usually you have to end up replacing the gasket but maybe you will get lucky and its just leaking around the bolt. Good luck
84 Camaro 305 ported & milled heads, 3 angle valve job, Edelbrock Performer RPM intake, Hedman full length headers, Accell ignition, Crane 274H cam, B&M 700R-4, 3000 stall speed, 4.10 gear,
M/T ET street tires
visit my website at http://www.geocities.com/jbenge/page1.html
Hotrodboba400
Dec 10, 2019 07:07 PM
db057
Apr 28, 2019 07:45 AM
86CamaroDan
Sep 29, 2015 10:08 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
