Cranking compression?
Car: 1982 T/A -1986 Z28
Engine: 383 -305
Transmission: T56-700r
hey guys,i just did a Compression check on both of my thirdgens
my 85 camaro LB9 with 78k on the clock did the following..
189 #1
190 #2
186 #3
186 #4
184 #5
191 #6
188 #7
185 #8
my 84 T/A l69 showing 71k on the clock did the following.
193 #1
190 #2
185 #3
187 #4
189#5
190 #6
191 #7
184 #8
any ideas on if these figures tally up to about what the factory compression ratios should be? both i beleive are rated 9.5 to 1,both cams are pretty much the same ,duration is,the lift is almost identical on the L69 and the 85 LB9.
any thoughts?
189 #1
190 #2
186 #3
186 #4
184 #5
191 #6
188 #7
185 #8
193 #1
190 #2
185 #3
187 #4
189#5
190 #6
191 #7
184 #8
any thoughts?
Car: 4
Engine: 6
Transmission: 5
They both look OK to me.
You can't determine the CR from a compression test. There are way too many factors that affect the reading. The biggest one is the cam; the less cam you have, the higher the numbers will be. I've seen 8.5:1 motors with 929 cams produce nearly 200 psi for example.
That test is really only good for telling the general engine condition; the absolute value of pressure that you should see with any given motor is something you can only guess at, the important thing is that they all be within a small percentage of each other. Within 5% is ideal. Looks like both of your motors are in good shape, as far as that reading is concerned.
skinny z
Oct 5, 2015 06:23 PM
