cheap engine rebuild kit
Old Nov 17, 2003 | 07:01 PM
TheViper's Avatar
Car: '84 Z28
Transmission: th2004r
i have a 350 i'm rebuilding. i need the usual stuff, pistons, rings, gaskets, bearings, freeze plugs, ect. where could i get a kit with all of this stuff in it cheap? it dosn't have to be anything special, cast pistons will do. do you know what the piston dish volume is in the summit kit for 9.35 compression?
Old Nov 17, 2003 | 08:41 PM
TheViper's Avatar
Car: '84 Z28
oops, wrong forum, could someone move it?
Old Nov 23, 2003 | 06:16 AM
radiateu2's Avatar
www.enginekits.com
Old Nov 23, 2003 | 06:58 AM
ede's Avatar
ede
there isn't really such thing as an engine kit sitting on a shelf waiting on you to buy. you tell them what you need and they put it in a box since there are so many differant combinations of parts you can have. i'd worry a bit more about running name brand quality parts than saving a few dollars. considering how cheap SBC parts are anyway and how competrive the market is any of the big mail order places will be close to the same price, and maybe even a parts store local to you will be better after you factor in the shipping.
Old Nov 25, 2003 | 09:28 PM
357mag's Avatar
Car: 94 C1500
Transmission: NV-4500
Axle/Gears: 3:42 10 bolt 8.5"
www.northernautoparts.com
basic Chevy 350 engine kit - $154.99
Good wrenching
Tim sends
Old Nov 25, 2003 | 09:47 PM
TheViper's Avatar
Car: '84 Z28
thats for an older block, i have an 87 which they want like $450 for the same kit.
Old Nov 25, 2003 | 09:52 PM
Magman's Avatar
Car: 1990 IROC-Z
Engine: 383 HSR
Axle/Gears: 3.70
My .02..... Spend the money right the first time. Low buck engine kits are just that, low buck. Reliability is out the window. A solid performing engine built with decent parts wont cost you that much more.
Old Nov 25, 2003 | 10:07 PM
radiateu2's Avatar
Viper go here for the engine kit www.enginekits.com and for the cam you can get a nice take-off cam here www.goautocenter.com
Old Nov 26, 2003 | 01:39 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Ok there are couple things you would need to use the cheap kit and you still save a couple hundred bucks.
RMS $24
Intake manifold gaskets $8
Valve cover gaskets $25
hectre13
Dec 11, 2023 08:14 AM
italiano67
Dec 11, 2016 09:21 AM
dutch930
Sep 11, 2015 06:58 AM
hectre13
Aug 26, 2015 08:17 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
