CODE 32 (EGR replacment???)
Old Nov 18, 2003 | 11:05 AM
Z dude's Avatar
Car: 1991 Z-28
Engine: TPI
Transmission: 5-speed Rear:3.73
CODE 32 (now what???)
I got the code 32 and looked it up and it says replace EGR valve
has anyone ever had this after adding headers?
and do I buy a new one or what??
thanks!
Old Nov 19, 2003 | 05:13 AM
Vader's Avatar
You may have to check your EGR valve pilot. Most TPIs used a negative backpressure EGR valve, but your's might be different, I guess.
You may also have an issue with the diagnostice temperature switch on the base of the EGR.
Of course, you need to verify that the vacuum lines are routed correctly and the EGR solenoid is connected to the harness.
mdtoren
Aug 23, 2015 12:52 PM
Out-Cast
Aug 17, 2015 10:57 AM
mdtoren
Aug 16, 2015 05:45 PM
