GENERAL QUESTION
Old Dec 22, 2000 | 10:20 PM
CAMARO-90-RS's Avatar
GENERAL QUESTION
I HAVE A 1990 CAMARO RS 3.1L . I HAVE AN AUTOMATIC TRANNY WITH 4 GEARS. I WAS WONDERING IF IT IS SAFE TO GO FROM 1ST TO 2ND GEAR AND SO ON MANUALLY WITHOUT DAMAGING MY TRANNY.
Old Dec 23, 2000 | 12:30 AM
89 CamaroIROCZ's Avatar
yes
89 Camaro IROC 5.7L 350"
ZZ4 Performance Cam, K&N Air Filters, 160 stat, Ported Plenium, Hypertech Airfoil, TB Coolant bypass, B&M Stage II Shiftkit
New engine on its way with a HOLLY instead of all this TPI crap.
Old Dec 23, 2000 | 02:40 AM
Bort62's Avatar
its also Safe to Turn off the caps Lock key.
60 Ranchero - Project ( Money Hole )
85 Z28 LG4 - Daily Driver
**Mods**
MSD Superconductors - Vaccum Advance Distributor
14" Open Element - Mech Qjet
KYB all around - Smog EQ Mostly Removed.
Best ET as of yet : 3 hours + to Drive To the Nearest Track
Old Dec 23, 2000 | 08:36 AM
ede's Avatar
ede
as bort pointed out not only is it safe to turn off the cap lock it's even desireable to do so.
ICON Motorsports
1st & 3rd
Old Dec 23, 2000 | 08:56 AM
Vader's Avatar
Kamaro,
GM Tech is one of the transmission experts on the board. He probably has visions of clutch packs, bands, servos, and valve bodies in his sleep. What little I know about the Hydramatics is that while they can operate as you describe, the oil pressure is regulated higher when in the ranges other than DRIVE or OD, so that shifts will be firmer and more positive. This might eventually contribute to premature wear of the clutches and planetary sets as they engage at higher pressures and with more force. It would probably take a while to do so, but I think the tendency would be towards more wear.
Any expert opinions on the topic would be appreciated. I've done some valving, adjustment, and servo work, but I haven't rebuilt an automatic since the PowerGlide days. I just keep clean oil in and never have problems.
Later,
Vader
"No matter how hard you try you can't stop us now"
Adobe Acrobat Reader 4.0
Old Dec 24, 2000 | 05:47 PM
SGT SWEETPANTS's Avatar
I might be talking out of my @ss here, but I thought that when you installed a shift kit (increases shift firmness and gives you more positive shifts) it increased the life of your transmission. This more positive shifting results in the clutches "rubbing" for a shorter period of time before engaging and, therefore, they do not wear as fast. I would think that shifting throught the gears may have the same effect. But, as I said before, I really am not sure of any of this, just what makes sense in my head.
'86 IROC-Z
305 LG-4, T-5
T-Tops
50k Original Miles
K&N Air Filter
Stage I Chip
KYB Shocks/Struts
Centerforce Dual Friction
Old Dec 24, 2000 | 06:38 PM
scoob8000's Avatar
Car: 95 Caprice
Engine: 5.7l LT1
Axle/Gears: 2.93
all of my tranny knowledge comes from past experiances, most of them bad, namely with the 700r4's.. at one point when i was having one rebuilt i had asked around at different shops about shiftkits, pretty much everyone agreed that they are rougher on your transmission.. they also suggested other ways to get the affects of a shiftkit without the downsides of one..
Americanmouse
Sep 7, 2015 12:10 PM
mustangman65_79
Aug 31, 2015 12:08 PM
Thaney9
Aug 29, 2015 03:16 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
