LS6 in 02?
Old Dec 21, 2000 | 03:05 PM
wm_sorg's Avatar
Car: 1991 Formula Firebird
Engine: 2001 LS1 Modded
Transmission: 2001 4L60E Yank SS3600 TC
LS6 in 02?
Gentlemen,
I read a rumour that the general is putting an LS6 in the bird in 02. Is the LS6 the corvette engine? What is the diff from the LS1?
Old Dec 21, 2000 | 04:12 PM
Rob P's Avatar
Car: 89RSconvtZZ4TPI
Engine: ZZ4TPI
Transmission: 700R4 TRIPP TRANNY
I think someone posted on another board that Scott Settlemyer (asst brand manager) said that there are no plans on putting an LS6 in the 2002 Z28. Sure would be nice though.
Rob P
89RSconvtZZ4TPI
92Z28convt5spd
71Impala convt 402BB
BETTER DRIVING THRU SUPERIOR HORSEPOWER!
Old Dec 22, 2000 | 09:47 AM
Dana'86_305's Avatar
I had heard from GMHTP that the '02 SS and TransAms would def. get the LS6
86 Camaro
LG4, Tuned Q-Jet
Edlebrock Performer Intake, Edlebrock Open Element,High Flow Cat,Dynomax Catback,B&M Megashifter, 160* TSAT, 3.42s, 800 Watt System
Old Dec 22, 2000 | 11:17 AM
wm_sorg's Avatar
How much power does the LS6 produce?
Old Dec 22, 2000 | 11:58 AM
dwang's Avatar
385 hp
385 ft/lb of torque.
i thibk motor trend dyno the z06 corvetee(ls6) and it is dyno @
345 hp at the rear wheel, so i guess it is underrated...
Old Dec 22, 2000 | 12:44 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
GMHTP said they heard the same rumors about the LS6. But I would imagine that it would only be available in the Firehawk and SS, in limited quantities of course...... may even be more HP by 2002.
James
If the women don't find you handsome they should at least find you handy
Aftermarket T-56 (pain in the A$S but worth it)
Lots of things to do still
Old Dec 22, 2000 | 12:59 PM
RED82TA5.7L's Avatar
Car: 96 Formula/82 T/A
Engine: LT1/350 TPI
Transmission: T56/TH350
isnt LS6 a late 60s BB chevy
RED82TA5.7L
1982 Pontiac Trans Am
Cross-Fire Injected 5.7l V8
Eldebrock Headers, 3" Hooker Cat-Back, duel outlet with quad tips.
Mods: 1.6 Proform Roller Rockers, electric fan, Corvette 5.7L computer chip, K&Ns.
Audio: JVC Kameleon CD deck, Jenson 4x6 front, Eclipes 6x9 rear, 2 10" mTx T4000 powered by a mTx 200watt amp.
Old Dec 22, 2000 | 01:09 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
That would be correct... the LS6 was a square-port 454 IIRC...
However the factory recylcles RPO numbers when they feel like it. For instance, the 93 LT1 isn't a mechanical cam 350 with double-hump heads and a Holley 3310 carb. For all we know, RPO code LS6 in 2002 would more likely be a transverse 3-cylinder than a performance big block. There's no magic in one of those codes.
Old Dec 22, 2000 | 08:35 PM
merf23's Avatar
the LS6 is the engine in the Z06 corvette (the 2001 car, not the 1963 with the 36 gallon tank)
Old Dec 23, 2000 | 01:01 AM
Mo's Avatar
Mo
ls6 was also used back in the day, i gotta a calender with a 70 chevelle ss in it with a ls6
Old Dec 23, 2000 | 01:41 AM
pat85yellowroc's Avatar
70 chevelle ss w/the ls6 was the factory 454/450hp wasnt it?? man, that is definately sweet.
beau-t-ful yellow 85 iroc
Old Dec 23, 2000 | 02:37 AM
Bort62's Avatar
a guy cruzed My Work Today with a LS6 powerd 70 Chevelle.
Him and his kid, Damn, My dad just HAD To be a computer nerd!
60 Ranchero - Project ( Money Hole )
85 Z28 LG4 - Daily Driver
**Mods**
MSD Superconductors - Vaccum Advance Distributor
14" Open Element - Mech Qjet
KYB all around - Smog EQ Mostly Removed.
Best ET as of yet : 3 hours + to Drive To the Nearest Track
Old Dec 24, 2000 | 07:07 PM
scoob8000's Avatar
Car: 95 Caprice
Engine: 5.7l LT1
Axle/Gears: 2.93
from what ive heard there are no plans for the ls6 vette motor to be used in the fbods.. the modern ls6 is pretty much a reworked ls1 as far as underrated, i recall reading in motor trend that the car they had had a slipping clutch
Old Dec 25, 2000 | 11:10 AM
bowtieguy01's Avatar
My dad wants to drop a lt-4 in his 93 vette, Then i told him about the Z06 and he went straight to the computer to find a crate motor LS6. Is it possible to find a crate LS6. He wants to drop that in and give me the LT1.
Bowtieguy01
Old Dec 26, 2000 | 09:04 AM
Craig84Z's Avatar
Car: 1984 Camaro Z28
Engine: Blueprint 383
The LS6 2001 Corvette did 330rwhp at our car show in August 2000. Check out Indy2k at www.indycamaro.com. This is the Central Indiana Camaro Club site.
Later,
Craig
84 Z28 305HO, 5spd, 220,000 miles, Edelbrock intake, Hedman headers, low restriction exh(w/cat), K&N air filter. Best 1/4 so far 14.649 @ 94.77mph
Old Dec 26, 2000 | 09:41 AM
ede's Avatar
ede
look closely at how gm writes the rpo the early 70s 350 was a lt-1 the 90s is a lt1 just like the 67-69 camaro was a z/28 and after that they all were z28. not much differance but enough to keep them seperated if you're up on all the rpos and such.
ICON Motorsports
1st & 3rd
Old Dec 26, 2000 | 10:12 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
ede I believe you are mistaken there... the actual RPO codes themselves have never had a dash. However, there was also an appearance package for the Camaro in the mid-70s, called "LT-1"; in about 78 or so that package got turned into the Berlinetta. Also you may recall that even though Z28 has been the RPO code for the Trans Am racer since 67, for a couple of years (71-73 IIRC) the badge on the car said "Z/28".
In any case, there are obviously only a finite number of possible 3-char RPO codes; since "L" codes are engine options, which tend to be fairly numerous, there is always a good possibilty that they will be recycled.
Old Dec 26, 2000 | 10:40 AM
ede's Avatar
ede
yeah you know what i mean, just not very good at getting it said. i guess i meant to say badging and not rpos. the vetts had lt-1 on the hood and we all remember the z/28 badges right? ther was an appearance package i believe now that you mention it in the late 70s.
ICON Motorsports
1st & 3rd
Mdenz3
LSX and LTX Parts
Dec 10, 2015 11:18 AM
Nervous2
Oct 8, 2015 10:53 PM
customblackbird
Oct 1, 2015 04:30 PM
Buggy Disaster
Sep 22, 2015 01:15 PM
sandman92084
Sep 12, 2015 10:27 PM
