GEAR DRIVE
Old Dec 25, 2000 | 09:06 PM
rdayz28's Avatar
GEAR DRIVE
I have heard you have to have your motor balanced before you put on a gear drive is this true
Old Dec 25, 2000 | 10:25 PM
JP84Z430HP's Avatar
Car: 84 Z28
Engine: 355 (fastburn heads, LT4 HOT cam)
Axle/Gears: 9-bolt, 3.27
I wouldn't think it would be a requirement, but it never hurts. The only reason I could think of would be the extra harmonics introduced by the noise from the gear drive.
Some of the noisy gear drives also affect the timing by creating a false knock signal on cars with a knock sensor. This has been discussed recently, so you kmay want to do a search!
Working on:
'84 Z28 LG4 305
Added dual elec fans.
145 MPH IROC Speedo
Building 430 HP 350
using primarily GMPP parts.
Block is in shop!
Awaiting results from all 8 ASE tests.
Starting to look like the Kicker poster child!
Old Dec 25, 2000 | 11:17 PM
AFBCamaro's Avatar
Car: 1991 Camaro RS
Engine: Blown 355 Small Block
Transmission: They always break!
No you dont NEED to have your motor balanced. As a matter of fact the engine will do better with one intalled. Unless your car is computer operated. In that case youll have to figure out a way of disabling the knock sensor on the engine so it wont retard the **** out of your motor. If you do take it out make sure you dont get pinging and use good gas.
Old Dec 25, 2000 | 11:43 PM
87RS402's Avatar
Chevrolet in their infinite wisdom used a single idler gear drive on some of the older 427 truck engines. These engines were never balanced and can still be found today powering 70's vintage 2-1/2 ton trucks. You should have no problems using one on an unbalanced engine providerd it's carbed. However, balancing can't hurt and I am a firm believer that it will free up a few extra horsepower.
Old Dec 26, 2000 | 11:43 AM
Guest
Guest
Posts: n/a
No, you dont need to balance it, but if the motor is out and apart I would do it anyway. As for the knock sensor, try and find someone who has a problem running a gear drive with a knock sensor... its going to be a difficult task. I dont have any problems with false knock with my 'quiet' gear drive. Willie has one too, and he doesnt have any problems either.
Old Dec 26, 2000 | 06:07 PM
rdayz28's Avatar
thank you guys my car did have computer is disconnected know
specialized
Jun 18, 2022 09:26 AM
jklein337
Sep 19, 2018 06:23 PM
jharrison5
Aug 19, 2015 05:53 PM
redmaroz
Aug 16, 2015 11:40 PM
