305 buildup
Old Nov 22, 2003 | 11:00 AM
clippjr8's Avatar
305 buildup
hi, im building a 305 ci engine for stock car racing and was wondering what the best factory 305 head there is available? has to have press in studs is the requirement. also has to be flat tappet. thanks
Old Nov 22, 2003 | 11:11 AM
pauldaniel26's Avatar
Car: 1986 IROC-Z28
Engine: 355 in the works...
I'm guessing your best bet would be a worked 416 casting.
Old Nov 22, 2003 | 11:12 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
416 or 081, depending on whether you want early-model or late-model intake bolt pattern & valve covers.
They're about the same other than the bolt-up issues.
Old Nov 22, 2003 | 12:12 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Every one around here uses the 416's because they came on our cars. I persoanlly like the 601's, ports are cleaner and the compression is a tad better 55cc.
Old Nov 22, 2003 | 01:16 PM
clippjr8's Avatar
are all these cast iron? thats what i need for this car because of the rules. also, what cam would you suggest for this head? this is a race car only, no emissions or idle worrys. thanks
Old Nov 23, 2003 | 10:33 PM
radiateu2's Avatar
416 and 081 are all cast Iron. Funny I was just looking at my 416 in my garage
Old Nov 24, 2003 | 03:53 PM
Sitting Bull's Avatar
Car: 1986 Sport Coupé
Engine: 305-4v
Transmission: 700R4 and TransGo2
Re: 305 buildup
All the guys are setting you on the right trail
If you want a guide to porting and polishing those stocker 305 heads just follow the link at the end of my sig.
pjsparts
Oct 29, 2025 06:39 PM
Ranbo108
Sep 9, 2015 12:20 PM
383cam
Sep 9, 2015 06:01 AM
rsrookie
Sep 5, 2015 07:08 PM
Formula_88AE
Sep 3, 2015 01:47 PM
