I know you've probably heard it a thousand times...
Old Nov 22, 2003 | 12:31 PM
Dioak88GTA's Avatar
Car: 88 Trans Am GTA
Engine: 5.0 TPI
Transmission: 700R-4
Listen, I KNOW that you will all probably hate me for asking, but i CAN NOT find for the life of me in any message board the specs for the STOCK cam and heads of a L98 AND LB9....what i've found so far....i think the L98 has the 083 heads? and the LB9 has the 081 heads? ok what i do know...and correct me if i'm wrong
L98 heads:
64cc cast iron or 58cc aluminum...
i don't know the porting of the valves...
LB9 heads:
58cc cast iron
no more than that
L98 cam:
i need to know everything there is to know
LB9 cam:
nothing i am sure of....
as you can see i'm very lost and i find different specs for the same stock heads....so my searching methods SUCK. ANY info would help so much and i'd love you forever! thank you in advance...
Old Nov 22, 2003 | 12:36 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
The cam specs are here..... on our homepage under Tech Data...
https://www.thirdgen.org/newdesign/tech/techdb.shtml
Toward the bottom of the page.
As far as heads, look a few posts away from this one.
"Question about heads"
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
firebirddude142
Sep 23, 2015 11:36 AM
buckshot63
Sep 10, 2015 09:15 AM
