very quick qestion on the '84 HO heads
Old Nov 19, 2003 | 11:23 PM
vic_V8's Avatar
Car: RS
Transmission: 4L60
just making sure that these are 58 cc heads before I buy a pair
thanks,
Vic
Old Nov 20, 2003 | 12:02 AM
300hpse's Avatar
Car: 1990 Trans Am
Engine: Lb9
Transmission: factory T5
Axle/Gears: 3.08 limited slip
if they are l69 heads, then they for sure are 58cc
Old Nov 20, 2003 | 09:46 AM
vic_V8's Avatar
Car: RS
Transmission: 4L60
thanks
Old Nov 20, 2003 | 12:56 PM
Sitting Bull's Avatar
Car: 1986 Sport Coupé
Engine: 305-4v
Transmission: 700R4 and TransGo2
DON'T pay anything extra for these so-called "HO" heads. They should be 416 castings and there is absolutely nothing different about them being on a Z28, believe it or not!
If nothing else you can get them from any junkyard for about $30 or so and rebuild them, after porting and polishing them.
Check out the link at the end of my sig.
Old Nov 20, 2003 | 03:03 PM
83 Z28 HO's Avatar
Car: 83 z28
Engine: L69
Transmission: BW t-5
Damn, only 30 bucks? I probably couldn't get em for a 100. Ahhh crappy salvage yards.
Old Nov 20, 2003 | 04:20 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
You can get a whole junkyard motor for $100 around here, about 30-40 for heads.
Old Nov 20, 2003 | 05:40 PM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
Yep, the 416 is a very common head on the early 80's 305's. They can be found in the Monte Carlo, Impala, Grand Prix, Cutlass, etc.
Pete
Old Nov 20, 2003 | 08:37 PM
83 Z28 HO's Avatar
Car: 83 z28
Engine: L69
REALLY?? If you see a good one next time you happen to look, could you let me know. I would love for a junkyard motor for 100 bucks. I can buy a 350 block, not punched for 100 bucks here.
Old Nov 21, 2003 | 05:13 PM
84L69TA's Avatar
Car: 4 Mopars total
Engine: Pentastar power
Transmission: T/F and New Process
Axle/Gears: Three 8 3/4's & one 9 1/4
My L69 has "601" casting heads on it.
Old Nov 21, 2003 | 08:42 PM
Engine: 305-4v
I currently run 601 castings on my 86 LG4, too. I got them from Apeiron, who took them off his 84 Z28's L69 several years back. I ported and polished them and they run mighty fine
Old Nov 21, 2003 | 10:07 PM
300hpse's Avatar
Car: 1990 Trans Am
Engine: Lb9
but this would disprove all that reading ive done about the h.o. heads being the same as the lg4 heads and also change what are considered to be the differences between the two motors (l69 & lg4), wheres the casting number on the head please and ill check my l69 to be sure, if they are not the lg4 heads, ill be happy
Old Nov 21, 2003 | 10:25 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
L69? What L69?
Old Nov 21, 2003 | 11:50 PM
radiateu2's Avatar
actually my 87 305 came with 081 heads. Just as good as the 416 for porting. Main difference is the angle of the 4 center bolts 2 on each side are drilled and tapped different. The 081 also has 1.84 intake valves not sure what the 416 have I think they are 1.94 intake
Old Nov 22, 2003 | 02:00 AM
Engine: 305-4v
Originally posted by Apeiron
L69? What L69?
Well Chris, you're the one who told me you took them off the engine in your 84 Z28, didn't you???
And seeing as I have your attention ...
When are you moving to Edmonton? Coming through Cowtown? What about Marquise's mom?
Old Nov 22, 2003 | 02:03 AM
Engine: 305-4v
No, you read pretty well correct. The 601 castings are just another 305 head from the early 80s. Not as common as the 416s but not a whole lot different. Mostly combustion chamber and bowl shape.
The casting is number is 8 digits etched on top of the head between the valve springs.
Old Nov 22, 2003 | 02:07 AM
Engine: 305-4v
The 081, 416 and 601 heads all have 1.84" intake valves and 1.5" exhausts. But they can all be opened to 1.94" for about 10 extra ponies above 5000 rpm
Old Nov 22, 2003 | 02:17 AM
radiateu2's Avatar
I think that when used on a 350 you can put in 2.02 intake valves given the extra bore size they can be made to be unshrouded pretty easily too.
Old Nov 22, 2003 | 12:40 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
My car was an LG4, and those aren't the original heads. I had 882's on the 350. The machine shop gave me those back by mistake.
Probably going to be in Edmonton in December or January, not quite sure yet. Haven't heard anything from Margaret about the book at all.
mike_c
Aug 27, 2015 04:32 PM
NinjaNife
Aug 23, 2015 11:49 AM
lakeffect2
Aug 23, 2015 08:44 AM
happyhapka
Aug 15, 2015 04:42 PM
