ESC
Old Dec 24, 2000 | 01:54 AM
xclr8tr's Avatar
ESC
Is this sensor the same for both TBI/TPI? From the outside, the sensor looks the same.
Old Dec 26, 2000 | 02:02 PM
Vader's Avatar
If you mean the Detonation Sensor (knock sensor), the sensor is tuned for the engine displacement and case design, not the fuel system. If you have a 305, the sensor has a lower threshold of sensitivity because the case casting is thicker and the cylinder walls are farther from the outer case wall than on a 350. If you have a 350, the sensor is less sensitive because of the reverse conditions. Both sensors will have the same appearance, so check the application.
Later,
Vader
"No matter how hard you try you can't stop us now"
Adobe Acrobat Reader 4.0
Old Dec 26, 2000 | 04:53 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
My dad just switched his TBI to SD TPI and he used a different knock sensor.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old Dec 26, 2000 | 11:00 PM
xclr8tr's Avatar
Thanks fellas. I played it safe and got the knock sensor and ESC. Dropping both in later this week.
L98GTA87
Oct 19, 2015 10:43 PM
GTAman
Sep 21, 2015 09:57 AM
RGB2015
Sep 20, 2015 09:26 PM
db057
Sep 4, 2015 07:57 AM
RyanJB
Sep 2, 2015 01:27 PM
