dying....please help
Old Dec 26, 2000 | 02:50 PM
jmon92conv's Avatar
Ok help me out here please. my 92 TPI is dying at stoplights after I get off the expressway. It seems like the idle does just not catch it. Also now my idle, it will idle in traffic(thank god), is about 1100 of it is real jumpy. Any ideas? if you need more info, just ask, I will try to help you help me.
Jeremy
92 Z conv
5-spd B&M shifter
home-made ram air, air foil, headers, no cat, TB bypass, kevlar pads, slotted rotors, BMR panhard, alston SFC
when it warms up Edelbrock STB maybe springs
Old Dec 26, 2000 | 05:37 PM
ssiroc86's Avatar
Its probably your TPS Thorttle position sensor. This manages how mouch to open the throttle bores at idle. Buy a code scanner from your local auto parts store they usually will run about $20 and will help you with future problems aswell. Hope this info helps.
Old Dec 26, 2000 | 07:33 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
https://www.thirdgen.org/newdesign/faq/thirdgen.shtml
Nice little article to into you to code pulling. Have paperclip handy.
For the idle, it could be your IAC, but does this happen all the time? Only when cold? Only when it warms up? Does the idle seem to be searching , or is it constant everytime all the time? Toss out a bit more info and we'll see if anyone can help.
"I don't want to be right - I just want to know if I'm right"
-Einstein
Old Dec 26, 2000 | 08:11 PM
jmon92conv's Avatar
Checked it first thing----no codes. Forgot to mention that.
Jeremy
Old Dec 27, 2000 | 10:20 AM
jmon92conv's Avatar
Come on folks....help a poor boy out. Thanks in advance.
Jeremy
92 Z conv
5-spd B&M shifter
Old Dec 27, 2000 | 12:16 PM
Keith5's Avatar
Car: C1500
My cavalier is doing about the same thing. If I run on the interstate for a while it starts wanting to die, but it can't while I'm running along.
When I get to the end of the offramp and start slowing down it starts trying to die. I put it in neutral and it keeps running. I have to wait at least 5 seconds or so til I can put it in drive again, if I don't wait a little and just put it in drive it will die.
After I let it set there for a few seconds and run in neutral it will be alright to put in drive and drive on.
I'm not sure what this could be, maybe the IAC valve, I need to check it out.
It doesn't throw any codes either. Maybe I just need to clean out the TBI with carb cleaner.
It's a 90 2.2 TBI cavalier.
1985 Camaro IROC-Z LB9
1989 Pontiac Firebird
Formula W6S LO3 TBI 305
-180 degree stat
-Hooker Cat-Back
Old Dec 27, 2000 | 12:23 PM
ViciousZ's Avatar
Car: 91 camaro
Engine: 383
Here's another vote for the IAC. I suppose it could also be the TPS, but I'm betting on the IAC. Also make sure there's no carbon in the IAC passage or behind the throttle plates.
[This message has been edited by ViciousZ (edited December 27, 2000).]
Old Dec 27, 2000 | 12:25 PM
ViciousZ's Avatar
Car: 91 camaro
Engine: 383
whoops! Double post. Now how do I delete this???
