increase mph on speedo
Old Dec 26, 2000 | 07:53 PM
stingerssx's Avatar
Car: '88 Firebird Formula 350
Engine: Built 383 TPI
Transmission: Built 700r4
Axle/Gears: 9 bolt, 3.27:1 Posi
I have the original speedo, and in other posts, someone said their speedo was inaccurate. someone else said that it could've had the needle removed and installed off. I was thinking, if I remove it, and install it straight down,(instead of at 7:30) then changed the numbers, would that result in a higher mph speedo? If I don't make sense, tell me.
'82 Firebird, dead stock, 9 bolt disc rear, over 200,000 miles and still going strong, more to come...
Old Dec 26, 2000 | 09:17 PM
Andy89RS's Avatar
Technically you could, but you're much better off going to a junk yard and just salvaging an higher mph speedo out of a thirdgen there. The work involved in making a new face that looks good would just not be worth it.
"Racing is life. Everything else is just waiting." - Steve McQueen - LeMans
305 TBI, T-5. 15.4@92 mph
Member Southern California Third Gen F-Bodies
AOL IM: Andy89RS
Old Dec 27, 2000 | 04:23 PM
stingerssx's Avatar
Well, the reason I did this was because the higher speedos are for electric speedo drive. I need to have a mechanical for the speed sensor that the computer reads from. I have a WC T-5 that has the electric speedo drive, and if I can keep it, and bypass the speed sensor, then I will get a later model dash. I can't install the tranny yet, cause of back problems. As for the speedo that I modified, I don't think it looks that bad, I just changed the numbers. I painted them silver.
Ed1LE
Sep 30, 2018 09:14 AM
darwinprice
17
Oct 11, 2015 11:51 PM
ZekeThorpe
Theoretical and Street Racing
35
Oct 7, 2015 07:30 PM
gord327
Oct 3, 2015 01:25 PM
hartsmike
Oct 2, 2015 07:11 AM
